Everything posted by mjrstar
I think someone in Australia did a bunch of work years ago on the old 1ggte cylinder head including cross sectional surgery.. Basically the outcome was the port area yielded next to no gain, small gains at the valve guide transition area, but it was really livened up once some larger valves were added to the equation.. I'm not sure if the same rings true of the 4age, although they would be of a similar Era to a boat anchor 1ggte so maybe the same dude from yamaha/ Toyota in Japan penciled down the initial design?
Crikey that doesn't sound ideal! Bracket wise I thought something like this would have been not too bad to set depth and height.. https://www.tiperformance.com.au/products/ea-eb-ed-ef-el-au-falcon-barra-accelerator-pedal-bracket-for-dbw-throttle/
Probably anything with a Barra. So 2002-2003 onwards? Or ford territory too I guess.
Later model falcon could be worth a look?
Aah right that one I can't get from my Mitsubishi parts stash.
I have a brand new mitsi one in a bag, which you can have so long as you replace it. But yeah these normally last pretty well in a standard application even with a good dose of boost / heat behind them. https://www.amayama.com/en/genuine-catalogs/epc/mitsubishi-japan/lancer/CN9A/sngf/intake-exhaust/turbocharger-supercharger/22499 Did I maybe send you a used gasket with the other turbo bits...
Have you tried doing down to a smaller diameter tungsten? And grinding to a very sharp point.
Throw away the stainless nuts on the vee bands, use copper or zinc passivated.. Also you can salvage the old v-band by tig welding a bit of threaded rod or bolt thread, if you find yourself short.
@Hyperblade owns this now if I am not mistaken, although it's pretty much unrecognizable from when Q had it!
The "full" mark is for when the engine is at operating temp? Is the cap on the expansion tank allowing air back in during cool-down to replace the volume of coolant headed back to the radiator?
I'd say the results of elevating the expansion tank would be negligible. Is the filler neck definitely compatible with the cap? Also when cold there is not really a requirement to have a huge amount of excess coolant in your expansion tank, its possible now that you have a larger volume of coolant you need to either start your expansion tank level off much lower when cold or run a larger expansion vessel..
Sounds like its not consistent pulling back from the expansion tank. I would look at the radiator cap seal and any potential for loss of suck from the vent hose when cooling down. The first thing i would do is carefully mark the expansion tank level when 100% cooled down and see if it returns to that level after a heat cycle.
Trans cooler /heater probably...
I was thinking last night with the brick shape of the truck you might actually have negative pressure at that side grille. You could try just reversing the fans as is to draw air from the underbody and punch it out the side grille (maybe minus the flutes). Pretty simple trial.
The fan(s) will be significantly more efficient as a push setup than a pull, especially as ram air effect pretty much doesn't exist in your case. Grab an a4 piece of paper and block off 1/2 the fan on the suction side.. Then try and do the same on the discharge! When you restrict the suction side even a little bit (with a radiator matrix) the efficiency drops off dramatically. The fans will likely be a litte louder when setup to push though. You could also consider a sandwiched setup with one push and one pull if that helped with packaging.. If you are stuck with a pull instalation, set them back off the radiator a bit and build a cowl/shroud right out to the edge of the rad core and seal the edges nicely with draft stop foam or whatever else you can find. None of this is really going to help the rate of fan cycling, as you need more passive airflow to do that (hence suggesting the ducting), but it will mean the fans run for less time to pull the temps back into line.
I assume there is at least one push fan we can't see? EDIT: yip i see your reply.. I feel there is not sufficient positive air pressure on the 'in' side of the radiator to force the air to turn 90 degrees with any sort of vigour.. I would tape some icecream container or similar bits to the side flutes to better catch/direct air and see if it makes any difference. Then send the info to @roman to graph for us. Also a pull fan is always going to be a bit meh without a full shroud as it will want to spill/ drag the easy air from the area at the blade tips.
Oh hey are these windscreen banners an actual thing? Asking for a friend of course not to go on my Pos racecivic.
Daves new school holden shambles. (And finally a Turbo)
mjrstar replied to Muncie's topic in Other Projects
Oh hey, I had a mission on a Ford territory a while ago, with a pile of fault codes.... It ended up being an intermittent voltage drop across the relay which fed the ecu.. Luckily the electric window relay was interchangeable.. Something to consider..- 359 replies
- not as good as a barra
- ecoboost
(and 1 more)
Tagged with:
Seems pretty light, my ek civic with not much interior, and a die cast aluminium engine block is 990kg. Although there is a few bits of rollcage materials I guess.
There are Honda guys running big vtec eliminator cams and they do see decent gains with a well sorted ITB setup. Which would closely replicate your wild 4age!
I don't like your chances of getting enough wrap on the crank pulley, and if you can the belt life is going to be compromised. Well unless you shifted the power steer to where the dizzy is.. I would multi belt that setup with one belt for alt, and water pump and one for the p/s.
Vise grips on the stem then whatever size 1/4 drive socket as that valve cap has / had a hex. You may be able to salvage the stem..
Aah yes vision, I have a wheelchair spec agm vision battery for my Starlet, it must be 6 or 7 years old and cheap as chips, it performs well.. I have this one in my mx5, it could be my install or cabling, but it's a little bit weak in my opinion.. https://yhipower.co.nz/catalog/vision---hp-102378.htmx?selectedProduct=856
If you have no parasitic load and a car you don't use regularly (like a race car with an isolator) the likes of a shorai are great.. I have one in my honda. Easily 3 months of ignoring the car and it'll fire up.. For a daily drive with stereo or alarm I would steer clear, due to the risk of bricking an expensive battery with a deep discharge...
Pretty sure airbox (maybe wheelie bin) on the end of trumpets ( I'm thinking those road cones you threw into the paddock) should net around 200kw.. This has been cool to watch / read, and the road cones showed real potential but then fell very sharply. I was sure they were going to punch a new all time high number..
