Everything posted by BlownCorona
BlownCoronas 1971 Toyota Corona
BlownCorona replied to BlownCorona's topic in Projects and Build Ups
Continuing through my checklist to get it cert ready, scored a half day on Friday so spend the afternoon at work fixing everything (or so i thought) first problem was that the handbrake cable went straight through the driveshaft hoop. so i made the spreader bar that the cable loops around and goes off to the two wheels slightly wider. and reshaped the driveshaft hoop a little. this also stopped the exhaust hitting the hoop. bonus. i also replaced a bunch of exhaust gaskets and its sealed up good now. but compared to the crown it sounds like shit, so that will require attention futher down the line, i might even put a massive muffler on and shut it up, letting the supercharger noise be the main sound. with all that done i was please and in the frame of mind that that car should be able to be booked in for cert, im not sure on the brakes. the datsun 1200 master cylinder has made the pedal feel not solid like a race car now. its a bit spongy which i expected. but it still doesnt stop very well. now im not sure if it really doesn't stop very well. or it doesn't stop very well compared to the recently sold Audi S4 i was dailying, which i fitted 325mm brakes to, and would probably throw you through the windshield. so i think ill send it for cert and if the cert man isnt happy ill figure out something then anyway i gave the wheels a rotate, and noticed the front brakes were dragging, im 99% sure the new master cylinder, although sold to me as a disk/drum unit probably has the drum brake one way valve things in both front and rear, so ill have to remove that and re bleed the brakes. no pictures cause i got into too much of a roll... -
+1 for putting the vtwin in something safer. i wanted to suggest that, and typed it out a few times but never felt right suggesting it given the situation. a caged buggy would be awesome with this motor + turbo
BlownCoronas 1988 Toyota Crown TC24SC
BlownCorona replied to BlownCorona's topic in Project Discussion
no worries. most can be had out of japan auctions for next to nothing -
Yes it was spintires. Excited to hear there's a new version. /spam
@HighLUX I chucked up some pictures of broken stuff in the build thread -
a post mostly for @HighLUX but i went around the car and took pics of anything broken i could see. obviously some are more damaged than others and some could be glued back together pretty easily. im mostly interested in a functioning aircon / radio button panel as mine is broken and i cant turn the fan off! and the radio surround panel. both parts i can get pretty cheaply from japan. im also interested in electric window switches plus their plastic surround. some of mine are broken and some switches dont work, could probably be fixed with a tickle up on the contacts though. its missing the bonnet trim, but im undecided what to do here. i dont really like how it bulges up with the trim in place. i may look at making something more smooth. same goes for the 2x missing lower door trims, im probably going to delete them all for a smoother look. the trim behind the door pull on the LR door is broken, but id be interested in a full set as they break so easy. Front Left corner light is cracked, might get pulled up on a wof, same goes with the Rear Left tail light, but i specifically want this style tail light as i love the way it looks compared to a normal style with the indicators up top. what ever the missing trim is on the "superwoofers" would be nice to get too. Also on the hunt for manual conversion parts. i already have a W55 and a G-W bellhousing. depending on what ratios suit better the option to trade for my brothers W57 is there. brother has a 1g flywheel for me. will probably just get the driveshaft modified rather than try and find a used front half. looks like i can get a brand new clutch pedal from amayama fairly cheap. just need to see someone about how to read the Toyota parts cataloger and what "sub assembly" actually includes. i might be able to do the same with the handbrake lever too, but the real tricky part is going to be a manual center console.
Does anyone remember what that computer game where you off road old Russian military trucks is called? I suddenly have a desire to play it again
Damn that's cool, never have I started reading a project thread and been so disinterested, and then so rapidly brought around as I have on this thread! "Heres a slogged out looking dyna I paid beers for, several pictures later and a few words and it looks like a beast"
ooh could be pretty interested in that! will put together a list of bits i need. not a manual by chance is it? and what colour interior? -
very likely. made the trip from auckland through kapiti on saturday and then through to christchurch late sunday. was an awesome cruise down, if only the rear diff wasn't geared so low and it could make any sort of power at alll uphill! that extra boost just makes so much heat and kills the HP. the car is pretty rough looking, but the bones are solid so it should make for an excellent car once a fresh coat of paint is applied. the interior is in remarkably good condition and will benifit hugely from a shampoo and wetvac i think. ill grab some more photos of the car when i get a few seconds -
So ive promised myself that i wont really touch this untill the Corona is certified, which its about 3 hours of work away from being ready to. but it needed a radio so i fit one i had laying around today and a small sub/amp. bought a brand new amp kit and with wires only just reached from the battery to the boot, its so fucking long. someone in their infinite wisdom fitted a really tiny blower pulley and it makes something like 17psi of boost, and a shit ton of heat and zero power once warm. it included the stock clutched pulley so ill probably refit that. plans include manual converting it asap. i have a gearbox here to suit and will be on the hunt for other suitable parts fixing the small defects on the body and giving it a paint job. rebuilding the shitty exhaust it has. sourcing some replacement interior plastics and a few lights that are cracked. fit an LSD that my brother hopefully has kicking around and sort out the final drive ratio, as the speedo is over 15% out and 100kmh cruise is 3100RPM! i drove from auckland with the little bell dinging, thank god for loud music. source some wheels. i may have a plan for some one of custom wheels. update the stereo components daily it and enjoy my life! i plan on keeping this one. Paint ideas currently are BMW Sepang Bronze, but this is not settled on, feel free to chuck any ideas my way. Discus how i probably shouldn't have sold a perfectly good Audi s4 to fund this project
As verified by your Chinese sensor
Currently enjoying a beer in kapiti, half way home with my new small project/daily. 1988 Toyota Crown TC24 Supercharger.
- 40 replies
- 25
if you dont care toooo much about power, id be seriously looking at 18rs. soch sideflow 2000cc 4 cyl. not the most modern engine option available. but setup a nice carb on it, and itll be reliable and powerful enough to daily, they were used in utes, vans and family sedans for a good amount of years. pretty sure they are more common over in aus too.
Depending on what he wants from the engine a nice 18r single cam carb might be a solid option too. A bit easier to get and with a reground cam and a weber 32/36. Become really quite a great and simple engine.
i have a w-r series bell i could sell if you wanted an r series engine?
megasquirt 1 (2.2) question. on my old engine i had the radiator fan handled by the ecu no problem, but ever since i switched to the twincam it hadnt worked, (it may just be that this is when i first noticed too) i had it setup to trigger a relay from the (-) side of LED18. but now when ever i hook up the relay to it it turns the LED off, if it was on. the ecu software is functioning properly switching the output on and off ect. i measured voltage at that neg pin and its ~2.5v when the led is off and ~5v when the led is on. it never seems to switch to ground like i thought it was meant to. any ideas whats going on here? maybe i fired the transistor somehow.
Job offer . Excavator operator chch.
BlownCorona replied to MightyJoe's topic in South Island Region
what company do you work for/own (if you do) would be good to add another company to the calling card for sometimes quite short notice work, centered around installing test sections of roadside barriers, but moreso the earthworks related to that. /thread hijack -
i have the rebuild green book from toyota if you want to know anything specific
can also confirm chain driven. have rebuilt an 18r, and also currently running an 18rg which is also chain.
i never realized you had a dyno in your shed. shit thats lux, top effort.
