Everything posted by HighLUX
Eastcapescapade #6 2022 November 11th, 12th, 13th
HighLUX replied to johnnyfive's topic in Upper North Island Region
Its awesome. Yes you aint the fastest but theres alot of serenity to take in when your nangin along at 55 -
All sorted -
Nah that ones still in my shed in a million bits -
https://tinyurl.com/3ee8wbd2 -
Already getting it sorted Bort -
Hemi2doz: The PG edition -
Sub $1000 mystery motorbike off trademe and send it plz -
Cant complain for $655 Needs the idle circuit looked at cause it wont idle but starts first kick and nangs happily off the clock on the flat.- 435 replies
Knock Knock....... Sues there? -
Outside hoist wrapped in Denso tape would do the trick
Should get one of my bikes going for this but meh will prolly just buy something to thrash for the weekend This is mighty tempting -
Didnt spot the NOS D21 tail lights?
Not the best turnout of vendors this year. Think the threat of the weather put alot off but it was actually pleasant for once, not raining or freezing cold
Or theres these rails you can buy with indents and threaded bosses so you slide the boss to where you wanna strap something down then screw on an eye bolt and ratchet things down. Some way to add those to the insides of the wellside?
Fill with water block up the holes and use a waterblaster like hydroforming?
Keen for a spot in the olds to go buy some junk
Or I think Mondeo is another good option for 2 speed fan that pump lots of air and should be easy PaP fodder
Fancy hilux at work has this but it gets confused by two 10kph signs right next to each other and says your good for 110kph
Bash plate plus custom sump that is wide and high? Mod pickup to sit closer to the crank and add big wings to keep oil capacity up so you get more metal to road clearance?
Did the same with my emission spec import hiace. Got a carb off a NZDM hiace bolted straight on. Blocked off excess vac ports and ripped out all the gubbins/solenoids. Didnt worry about the dizzy. Powered up the auto choke clock spring thing and it worked perfect off the bat. Ran way nicer with better economy, would start and idle fine with the idle dropping back as it warmed up.
Tauranga / BOP Monthly meet - Discussion Thread
HighLUX replied to Connor's topic in Upper North Island Region
Nah in napier for training for the next week and a half Enjoying some doggin with @TimShadboltfan27 instead -
Pretty sure the coolant loop for the TB is only for stopping it freezing up in cold temps. Have you cleaned the IASC? Even abit of carbon on the barrel will get it sticking and making it idle high. They dont run a cold start injector like earlier motors so its really up to a wiring problem or a sticking IASC. I remember @Spencer saying they needed a voltage signal after key off to reset the IASC otherwise they did the mischief your talking about or something similar
HighLUX replied to h4nd's topic in Other Projects
Perfect accompaniment https://www.trademe.co.nz/a/marketplace/gaming/pc-games/strategy-puzzle/listing/3596563464?bof=By9rxp2Y -
Mod powers incoming, you should be able to edit it soon and get all dem mod benefits -
@GuyWithAviators wanna try fire things up again I can come along in my not OS corolla and regale tales of not doing any work to my OS car
