Everything posted by Bling
Forgot to add, either get a local hookup, or try Amazon.com for much cheaper options (same brands). Either try find one with direct shipping to NZ, or bang it on Youshop. Would need to try one on locally though for sizing.
Good and cheap won't exist. By good, I mean one that stops it getting into your eye balls as well as lungs. You only get one set of each, so look after them.
Not OE anchorages if you're adding diy'd bits to them. IMO. Who is to say they are up to the job if a certifier isn't checking. I'd say money well spent getting it certed if safety is the main priority. Just my2c though.
Bling replied to h4nd's topic in Other Projects
Built a wheel polisher years ago. Had mechanic I use turn up an axle I swapped off someone. A couple of pulleys, a belt, a section of steel beam, some bearing carrier things and bobs your uncle. Used it to polish one wheel. Most expensive polish ever. Have since moved it between three houses which isn't fun given its weight. Plan to polish more wheels in the future.- 1289 replies
- 15
I was just surprised to be honest. As for if it matters, I doubt it will. Unless you have an off and the car is inspected by insurance.
Could you trim both to be symmetrical? Frame will need adjusting obviously, but that is easier / cheaper than remaking one side perhaps?
- 27 replies
I started fixing some rust like that on my old Corona. I stopped grinding the paint back when I got half way to the other end of the car... Sold it for parts. It's only metal though, if you have the time, patience and skills, it's fixable. Miss that car, I just lacked the space and skills to fix it at the time. I didn't find the rust until after I had shelled out $$ for less rusty bolt on parts. Sold it to someone on here filled with all the spares for cheap. That's my shitty story
I thought you could remove the rear seats and belts in this situation?
I find my BOC MIG sweet, got it before they did those all in one units though, they look flash as fuck. I bet you'll be happy with that!
Unless they are talking about that specific welder not being any good, I'd say they are wrong. 150A will smoke most home stuff no worries. The problem with panel steel is often cheaper welds can be a bit unstable at their lowest settings. Might just take some fart around to get the settings right. What sort of settings does it have? I have welded (just to try it) 0.5mm sheet with my 180A welder no worries. Most of the time the sheet I have welded has been closer to 1mm, which gives more leeway on not quite having the settings bang on. I've been nowhere near the top end of my welder, and have welded reinforcing rod into a frame, which was 16mm or so diameter. In all fairness, I just turned the settings all up quite high, and hoped for the best. The top rating is only part of the equation though, minimum amps is more important for panel stuff. Really need more deets on all three welders mentioned. If you plan to weld 10mm sheet to things, then you're talking higher amps, but for most garage stuff, you won't get near the max setting IMO.
I roll M12 at home, have circ saw, drill, polisher, torch, multi-tool, hackzall, inspection camera and impact gun (brushed sadly). Misplaced the impact gun during moving, so hoping to find it when I unpack storage unit, never even used the damn thing Rate the gear for sure though. I usually wait till Milwaukee are running redemption specials. Got the inspection camera free when I purchased the polisher. Got the hackzall free when I got the drill etc. Good value that way. Roll M18 at work, for serious jobs that would be the way to go. M12 impact gun is good for the small stuff. Saw a builder using a M18 brushless impact gun on a site and it looked impressive as fuck.
Two people like stock height therefore times have changed? Interesting. Sack it and brap it, Uterus knows what's up.
Sweet haul of old Audio gear in Christchurch
Bling replied to Threeonthetree's topic in South Island Region
My guess is they picked out all the good (working) stuff already. -
Could be worth checking out the indicator stalk condition too, assuming headlights on the same stalk as indicators. Only place I can think of that indicators and headlights come remotely close wiring wise. Could be well off though, I can't suss my own electrical issues
Goes hard for what it is, will ring true. I miss my blacktop and that was in a heavier FWD platform. Stock power will put a smile on your dial easily.
Same again next month?
Was planning on going, but it clashes with Chopper Next time, was keen on some greasy food and sharnsTBH.
Air gap provides the "insulation" I think, I wouldn't bother with it TBH. Polystyrene could be worth a look, but I probably still wouldn't bother for a playhouse.
Good plan.
Built to last! Dressed timber looks so much nicer than RS, which is what I tend to end up with due to budget.
Seems like a list of maintenance issues rather than things related to the modifications? Any comments in regards to the mods or did that all go through no probs? 300 horse seems damn good for that motor!!
Hi Pete, Long time! Hectic week this week, but i'll get in touch next week and pick your brains / show you what I have. Cheers!
Nah not that one, but looks pretty similar. Was using this till it got sold, big unit, but spent half my time making adjustments to try and get square cuts.
Auction finished already haha. Will edit a link here when not on phone.
