Beaver
Area Reps
Everything posted by Beaver
  1. So now that this appears to be working properly, I'm slowly working through some tidy-up items etc. Will look to install a catch can for the oil breather as its making a bit of a mess of the intake and turbo. Temp gets up a bit while driving, nothing too concerning but runs a bit hotter than the n/a motor for sure. On one long hill in particular I could see the gauge slowly rising. When I got the car the radiator was stuffed and I got it rodded which fixed the issue with overheating at the time, but might not be up to scratch for the turbo motor. Looking at factory radiators from a patrol (which the engine came out off) they are much bigger than the gloria one. I think I remember someone saying r32 radiators fit, and can get decent looking alloy ones for reasonable coin, so will take a closer look at that. Still need to get around to drain the fuel tank and cleaning everything out etc. Will use up some more diesel first.
  2. This thread is almost as bad as how manu/Steelies should have moved His container house.....
  3. Rode it yesterday on my mtb, was a confusing sign that said closed to anything bigger than a four wheel drive motorbike.....was at an intersection tho at the start so may have been for anothertrack. Came across one 4wd and few quads as well driving it, as a handfull of 4wds parked up at at the shack things not far in from the start
  4. New filter got me home good as gold. So other than that keep not setback it aced its first trip (~900 kms) with the new motor. Such improvement over the old one, 5th gear everywhere and hills are no longer something you have to mentally and physically prepare for. Oh and a dude in levin told me it was sick, so clocked life right there.
  5. Wondered who the random txt was from..... haha. I’m out of town sorry!
  6. New filter did the trick for now, actually pulls noticeably harder than before which is a nice bonus. After letting the shit I drained from the old one sit over night, it looks a lot less like rust/crud and more like what the internet says diesel bug looks like. so I think it’s best to drain the tank and clean everything out, fun times ahead. I got a spare filter as well incase it blocks up quickly.
  7. Yeh once I get home I’ll drain the tank and see what that’s like as well
  8. Beaver
    diesel spam
    Well I have to get home first so I’ll get a new filter to get me home then give everything a drain and clean. Once the shit has settled out a bit better I’ll tale a closer look but it defiantly felt sludgy and not metal/rust.
  9. Beaver
    diesel spam
    Not that I could tell
  10. As per diesel thread, on our trip north last night got real bad surging under load. Long storey short I drained the fuel filter and found this Yummy. Unfortunately I’m in National Park/some distance from parts shops and nothing is open today anyway so off to Taupo tomorrow with the inlaws to grab a new filter. Might grab two haha, not sure where all the shot is coming from so probably not a silly idea
  11. Beaver
    diesel spam
    Anyone know what diesel bug looks like? This is kinda like dirt sludge with flakes.
  12. Beaver
    diesel spam
    so drained the filter...... god dam Easter with nothing open haha
  13. Beaver
    diesel spam
    How to I check the water trap? I open the tap thingy on the bottom of the filter and diesel smelling liquid came out.... I’ll give all the hoses and fittings a one over and check for blockages
  14. Beaver
    diesel spam
    Good thinking, shall do that. Whipped the top of the boost aneroid off to check the diaphragm, no leaks but the pin was pretty gunked up so have it a clean (and put it back in the same place). Doesn’t appear to have changed anything so can cross that off.
  15. Beaver
    diesel spam
    Roger that. Check as in visual inspection or is there an actual way to check if there is air getting in?
  16. Beaver
    diesel spam
    Internet diagnosis time people! Rd28t stuttering/stumbling under boost. Left Wellington last night and all was fine and dandy, but after a while it started surging (power would cut in and out, felt like driving into a really gusty headwind) when trying to accelerate at any decent rate. Got worse over time. I topped up with diesel from half a tank along the way and I can’t be sure but I think it was not long after that that I first noticed it, but may be a coincidence. initially I could drive around it by keeping the boost down and not giving it full beans, but by the time I arrived at my destination (300km), it was stumbling just keeping a stable speed. any ideas on where to start? I plan on checking the fuel filter (not sure what to check for haha), and obvious things first (leaks etc). Was also thinking perhaps a leaking/torn boost android diaphragm? As it feels Iike when it’s Making boost the fuelling is all out of whack. oh and it starts as it’s always starts (I.e. fine) and will rev out cleanly with no load. cheer!
  17. You probably know this already but when going low on these you get mega camber and toe in at the back. Might be worth looking into options to remedy that considering the effort you are planning on! keen to see how things end up
  18. Sounds like something butlers would have?
  19. To all you jokers hounding me to lower it...... youll have to keep hounding. Just replaced sway bar mounts without jacking it up. Such practicle
  20. I has guitar strings if you need Al. Are the single wire ones best or the wound ones?
  21. Don’t listen to him, current wheels look perfect!
  22. Perfect
  23. It only has one. So removing it and replacing with pipe sounds like a much better idea.
  24. Why add mufflers when you can remove mufflers.
