Jase
Everything posted by Jase
  1. l series petrol and diesel flywheels are different depths i've found, only since bolting an ld to an l28 patrol gearbox, the ultimate box would be from an mq safari lwb with divorced transfer, as they are a 4 spd bus box essentially and the Bedford won't put too much strain on it
  2. the brass copper combo is more ductile than the alloy, so other than being better at heat transfer it can also expand and contract more readily than the alloy with each heat cycle. you will also notice some alloy rads have the tubes bowed in the core so that with expansion and contraction of the tube it is not ripped from the end tanks. a lot of the trademe ali jobs suffer from cracking of that nature
  3. concur^ you'll find with lsd front an rear it'll walk everywhere, even better with an auto locker rear an lsd front so its not too piggish to steer if its a daily
  4. when you look at the bike they came from can you work out how much airflow it was consuming and the airspeed it was generating at idle to drag the air in at idle past the fuel to get efficient mixing. eg 1200cc bike will consume 600cc of air per revolution of the crank, at 1000rpm its going to consume 10000cc of air per second or 21.1888cfm - which would be 255cfm @ 12000rpm so then your 2000cc car will consume 1000cc of air per revolution , at 1000rpm its consuming 1000000cc/s or 35.315cfm- or 282cfm @8000rpm now from what I can remember most flatslides run a venturi to spray the fuel up from the jet when the needle is lifted, maybe this needs to be resized to match the increased airflow demanded of the carbs and also the increased volume of fuel from the jets required to achieve the correct mix for the larger engine. Also of note is most bike carbs run with an airbox extremely well, the airbox's I've seen always have relatively small inlets, could the small inlet be aiding and increasing airspeed down each carb through its restriction. Also watching your vid could the airflow from your fan be disturbing/upsetting the carbs? as normally they'd draw a relatively undisturbed supply from the airbox only really effected by inlet pulse up and down the airbox and supply and demand variation due to throttle opening
  5. its not over full? as that'll froth the oil up and drop pressure as the pump picks up air laden oil.
  6. I did the same went drum to b2000 discs , then I had some b2000 stubs modified to flip the bottom balljoint. the stubs got the bottom taper milled out then a stepped bush with the new taper got pressed in. it sees the lower a arm sit flat and would remove catseyes with the x member. those stubs are shelved as the ute wouldn't get out the driveway on them. make an offer if you want them, I'm looking at ordering a water to air for the daily so any extra funds would be handy
  7. seemed to have solved it, fuel cut solenoid or idle up solenoid was still getting power after ignition off, unplugged that and went for a ten minute drive along with a quarter turn out on the mixture screw and its gravy. cheers chap bloody butchered together ford
  8. so my little truck likes to diesel itself , it idles smooth at 1000rpm when warm, timing was set with a light at 12deg before tdc with vac advance unplugged, vacuum sits at a steady 500mmHg at idle and drops off as it should. it runs like it should but runs on at shut down? it doesn't pink on acceleration and does smell a bit fumey could the rich mix be leaving a pool of gas in the intake? the carb does have what seems to be a fuel cut solenoid which I have checked but will double check the circuit powers down with the ignition off. it did have one blocked idle air supply jet which once fixed sorted a high idle issue it had. any thoughts?
  9. hey tom you buy that sfi from jegs? I have two glides here one which is already a two piece case and built for a bit it got a big block pattern bell though so looking to match to ls did you buy the ls to glide one or the other?
  10. for 1.5mm to 3mm a side heat with blue crescent till bright amber whilst clamped in a press , then pump it down nice and level with a block say 10mm off your clamping block. should be able to get a nice little side shift in the plate whilst keeping it parallel easily with correct setup. ie that is run a bit of 1.5-3mm plate on the underside of the material where it is clamped leaving a 3mm gap for the steel to be shifted
  11. I have an old pajero tow point dynabolted to the floor in my shed for this reason, you can run a snatch block and cable under the bus and tow it in with another car. without knowing where it nipped you're pretty much poking in the dark. or just put 50psi in the tyres get some chaps to give you a push/insert buick v6
  12. uterus is correct in the sense that the pump doesn't restrict boost at all, other than failing to supply adequate fuelling to get the combustion to a level where the turbo is at its most efficient. more fuel will give higher egts and egts over a certain point will eat pistons rods blocks, diesel can be somewhat counterintuitive to a petrol head where a rich mix is safe for petrol it is the opposite for diesel, run lean with a diesel and you will be down on power but the egts stay very low. get an auberin egt gauge in there and have a look at your temps before you tune. certain engines won't handle high egts (1hz etc) due to thin piston crowns
  13. yeah does wildplumdx still hang about I'd like to borrow that timing gauge for my ve pumps, you want more boost add more fuel chap, pay to get an egt gauge first though
  14. cut down redrilled axle flanges would be a good start, if an axles out the shafts are quite beefy and 30 spline, also the driveshaft flange only comes in a couple of styles, post a photo of the top of the head I have a few here to compare with
  15. scribbulon aka sexychevette incarnate/ probably just old heads will get that
  16. since when is anyone sensible on here, I've poured thousands into $1000 dollar vehicles for years. its a great way to pass the time. do what floats your boat young chap and don't let anyone tell you your interests should be different. originality comes from those with the willingness to be different and follow up there ideas. unless you want to carbon copy the latest trend?
  17. yeah Nathan you forget he's a young chap, studying flatting an living off a student allowance is pretty tight on the money side, depending on his commute distance a turbo diesel could be quite viable, it isn't common to see diesel swaps here into passenger vehicles but it does make good sense especially as a first swap. not too many pitfalls with wiring (glo plug relays etc) plumbings fairly simple and engines not going to be too big for the hole, brakes may need a little upgrade (pads/rotors) also insurable for a young fella. A first engine swap should be easy, make mounts plumb it wire it, get a driveshaft made, cert it and go. Otherwise you'll spend the next ten years looking at the thing in the shed like me
  18. if fuel consumption is a concern, how about a hearty turbo diesel with some pump mods, obviously its not a common swap but I have a ford courier 2.2 diesel and 4 spd that would work well. keeps it in the family and with a little extra plumbing for a fuel heater it could be run on chip oil or black diesel
  19. different car, one I know of could likely be had for a couple hundred. have you considered a rotary swap? a little ported up 12a or 13b would kick an escort along fine. annoy the neighbours etc.
  20. theres a 4 door up north I know of that has been sitting a few years likely get it for cheap. already cobalt blue with white turbos, first step is buy a Haynes though very first investment regardless
  21. should have been on A class rego if you were doing work for wof, council has reimbursed me for a wof fine when I pointed out it was legally allowed to be on the road outside a repairers workshop with its A reg and no wof. I also sent them a letter explaining that I could not afford to pay an unjust fine and that legal aid to fight it would cost all taxpayers. Then politely asked them to look into the legitimacy of fining a vehicle that was correctly registered without a wof.(my interpretation vs. their interpretation) I received a letter back a week later saying my fine had been waived due to the correct registration being in displayed. Bad news for you is pay the fines or plead broke $1 a week
  22. yeah cheers fella you're a star. as far as cage design goes , will they be looking for engineering calcs to prove point load ratings for the belts? or will plenty of overkill and triangulation suffice. was planning on using heavy wall steam tube and bends where possible and then my hydraulic bender for the main hoops and larger radius stuff
  23. cheers clint , would an external cage be acceptable , as wearing a helmet day in day out would be annoying. tbh it was on the list anyway although I'd failed to add it
  24. hey clint, I have a certed 88" ld28 s2a chassis/truck with a rotten chassis, I'd like to put 109" chassis under all the bits I have, the list ld28 + t dual mq safari boxes safari diffs on std lr leaf springs (parabolic conversion) station wagon to truck cab conversion 12v tipper deck big tires my question is mainly based around the swb to lwb conversion of the chassis as upon recert I don't want to be stonewalled due to the swap as it would no longer be the original chassis although it would have been a factory delivered option to choose chassis length at point of sale? any thoughts?
  25. and over driven gears that tend to get a hard time, big picture I'd like to keep my breakages limited so I will start with the truck running open diffs, obviously crawling spots are a bit limited up here unless I go play in a quarry or river bed, if it fails to perform i'll head to lsds and chromoly cv's. how about running the overrun coupler between them? back box will have no clutch and still be being driven along with input and gearset by the driveshaft whilst underway so an ability to free wheel when the shafts speeds are mismatched seems a good idea, obviously reverse would need to be selected from the back box as the coupler would free spool if it was selected on the front one. pretty sure the truck setup was a direct coupling but the gearsets and shafts and strength concerned was somewhat increased over these little bus boxes
