Everything posted by Nominal
The continuing process of remaking the bottom of the B-pillar. I've been doing it in smaller pieces to keep the shape references. This area is almost all hidden when the wood and sills go on anyway.
- 111 replies
- 40
+T and straight pipe FTW
Nominal replied to Muncie's topic in Other Projects
I don't understand, you haven't driven it for months and you are worried about the price of petrol? If you want an economy car buy a Yaris.- 742 replies
What you need is an ld28 with a 100a alternator on a run stand.
Pick picky, how about this one AutoSpeed - Dirt Cheap DIY Battery Charger
Knock up a couple of trickle chargers from plug packs? AutoSpeed - Zero Cost Trickle Charger Don't buy a small CTek charger and expect it to work on a car battery. It won't.
axl /spam As for the question, it shouldn't matter from a braking function point of view, so whatever is convenient for the plumbing/bleeding would do.
Keen. -
Took the working one away to Ohakune. Went well even after the frost so took a spin up to Whakapapa. Annoyingly left the petrol cap at National Park g.a.s and it wasn't there when I went back 90 minutes later so who knows what happened to it. Managed to find a substitute at Horopito Motors after sneaking entry on a Sunday when they were sort-of closed.
- 111 replies
- 38
Another month already? Hot Rod club came for a visit so pulled some wood out to make it look like I've been making progress After getting some more steel I made a start on the bottom of the B-pillar
- 111 replies
- 27
Make sure you follow the correct process though Engine Myth: Urinating on Cylinder Block Improves Durability - EngineLabs
Well, you certainly beat it up. Good job!
3 generations of Muncies impulse bought the same GN125.....
Nominal replied to Muncie's topic in Two Wheels
That's a weird kink. -
Nominal replied to yoeddynz's topic in Other Projects
Hope you and Hannah and going to mod some cycle helmets to reproduce that look. -
It's a shit situation, hard to believe the seller didn't know the engine was in a sad state. Maybe return it and then go to disputes tribunal for the shipping $?
Hey, at least you are getting plenty of practice at engine removal.
- 138 replies
You could get a cert/wof set and a different "off-road' set and swap them around.
Are you going to be like this guy and telling bystanders that "it's not my car" -
Floors look good Elle, will make it easier to work on the house part now. I saw you laminated beam parts cut out at the friend of a friends place in the weekend, should look nice when assembled.
Yeah, but none for @SOHC's letter either.
The Alpha (worst ones) can be searched here Takata | Compulsory Alpha Recall (nzta.govt.nz)
Nominal replied to yoeddynz's topic in Project Discussion
Shouldn't you be following that other classic rear engined flat 6-cylinder approach and have six pipes out the back? -
Not on my behalf, I'm mostly wfh still and have already been to town one day this week. -
Any plans @Mourning Cupcake? Seems like Jville weather.
