Everything posted by Nominal
Got this out of the chicken shed last weekend, WOF expired in March. Noticed that the accelerator pump was leaking quite a bit, seemed to be worse than it was previously, dripping on to the inlet manifold. I had a rebuild kit for a 4-barrel Autolite carb that I might install one day, instead of the 2-barrel that is on there now. It's a pretty easy piece to access so I pulled it off The replacement diaphragm in the kit has two pieces (a separate pushrod) compared to the one in the carb. I ended up using the cover from the 4-barrel as well as the shaft seal seemed to be leaking on the 2-barrel one. Also cleaned up and repainted the air cleaner lid. Don't want to get too carried away in the engine bay though. Might be a bit easier to cold start now with a better accelerator pump, it used to take heaps of pumping to get some gas down the carb when cold. Next is sorting a WOF check.
- 69 replies
- 21
Agree. For the extra $1500 it seems worth it.
All off now, bit faster on the second side as I knew what I was doing. There's a fair bit of sticky sealer on the body side, not sure that all that is necessary, will do some research before it goes back together. First side has been been stripped using a heat gun and given an initial DA sanding. I need to go over them again and check the details, then go down a couple of grit levels to 240 or so.
- 102 replies
- 26
I bought a home made one, built from angle iron. It had been built with air cylinders for clamping, but they were rubbish - not enough force - so I converted it to bolt clamping. Was sort-of OK, but I got rid of it when I bought an old cast iron folder. It's not fabulous, but works OK if I tighten the clamping nuts down.
@tortron's massive tool
- 102 replies
- 21
The panels are held on by bolts/machine screws that do into the blind nuts with the stainless covers. Had to remove the spare bracket and the taillights from the tailgate. I found some extra screws that were holding the panel on after pulling a couple through the steel panel, oops The panels are held on by a billion screws, luckily not glued (or at least not much) as well
- 102 replies
- 21
When the 49 was put together about 15 years ago the veneer panels were quite a bit darker (pic found on flickr, dunno what happened to that roofrack) The have faded now to tone in with the maple framing - pic from Turangi at Labour Weekend Also the clear finish on the wood was starting to break down at joins and on the panels themselves My guess it that is 2K automotive clear coat, although I'm not 100% sure. While durable this doesn't suit spot touch ups or overcoating when tatty. The only way to deal with it is stripping right back to bare wood and starting over. So, after getting back on Monday....
Another drive-by that's probably not worth replying to? Any swap is going to be a lot of work and $$, and probably not worth it.
Nominal replied to yoeddynz's topic in Project Discussion
Not if I didn't already have something sitting around.
Well, do the epoxy thing then.
Is the vehicle a keeper or a seller?
I've had to resort to emailing them! -
Yup Only get the one photo on the auction...? -
That's taken a beating.
Scope creep limitation device ToolPRO Gearbox Stop Off Tool | Supercheap Auto New Zealand
Eh, how about next week instead, or skip it? -
Any plans for Thursday @Mourning Cupcake? -
After some research and talking to a yachtie relative I used some Altex epoxy sealer first A couple of coats of that then five of the varnish It's a lot glossier than the sikkens finish, hopefully will stay looking good for a few years, and can be scuffed back and refinished without completely stripping it back again. Reassembled and back on the road after about 6 weeks. I do need to make some protective covers under the wood behind the A-pillar. This area had some new wood put in by a master joiner last year.
- 102 replies
- 31
Wooden car distractions. It's been 17 years I think since this one was re-finished with Sikkens outdoor furniture finish. It's lasted well but needed re-doing as it had failed in some areas and the wood was turning grey. A number of evenings with 80 grit sandpaper, head gun, scrapers etc got it off. Just did the exterior this time, and left the side glass in. Hope that doesn't bite me in the future. Bleached the wood to tone in the different coloured areas with Oxalic acid. I used some leftovers to clean up the Townace, it works well in removing rust stains and random overspray from careless previous owners. Looked good when dried out.
- 102 replies
