peteretep
Everything posted by peteretep
  1. do you have a compressor to blow into the crankcase if you think its super flooded?
  2. We use spraywell at work. Apparently the trick to getting a better price is to go around the back on the left hand side and find the younger dude (son). The dad charges more. Also the charge prices seem to come out their bums, they just pick a number. Good quality finish though
  3. ah yeah those look legit
  4. trailtech do a TTO model which means you can get a rev gauge and a temp gauge separately. I have a trailtech vapor on my street magic which is twice as much as the two gauges, but has more info on it. Trailtech stuff seems legit. I have a stage6 gauge on my other bike and its not too bad, but the trailtech is better IMO https://www.trailtech.net/tto
  5. You got something to check temps?
  6. If the angles are the same I would probably just chuck a decent sized washer in there, just make sure the ID of the washer clears the taper. Maybe a couple of pics would help
  7. Dont forget idle jets, main jets, needles. And rollers too
  8. so rad also so tiny
  9. I have to say, I dont understand why you persevere with this bike. But good job for keeping at it
  10. Jeez I haven’t been winded in a long while, maybe I should get a ct
  11. I ended up buying a drill doctor for $270 from NZ as it was a present and I wanted to buy something decent. Not sure about OG pricing but It’s a nice unit
  12. doesnt look like magura to me, my dad had a set on an old bike that didnt look alot like that
  13. A normal bulb will run on ac no worries, but LED’s need dc. If you have a soldering iron I can tell you what bits you need to buy to make it work, costs less than $10 to convert it from memory
  14. I put LED’s on my aprilia but I had to convert from ac to dc for it to work
  15. hey guys is someone available to go check out a motorbike for me in upper hut in the next couple of days? I dont mind paying for your time/gas etc. If I go ahead and get the bike would be cool if someone could store it too
  16. Fucking so good cheers everyone
  17. dang what is that thing? how fast is it?
  18. Hey @Truenotch how does the oil system work? I see you have changed to premix but is the oiling adjustable, or some way you can see if it was working properly? I put a drill to pump oil on both my scoots to prime them/check them. My Suzuki has a non adjustable oil setup but the aprilia is adjustable
  19. Nordson is the most common in NZ, mostly as they have the best service really, just screw you over on pricing, plus everything is imperial and yeah, does change depending on viscosity, but I dont have that info and I trust that whoever helps us set up the machine will set it for best results.
  20. there is pressurised glue in line feeding the guns, the times relate to the pneumatically operated solenoids which open the valves for the pressurised glue lines. We can measure everything pretty accurately as the cardboard is moving via servo with encoder feedback. Problem with that is we need to buy a machine to test it, costing $25k
  21. Hey guys I have a work related question, I am designing a machine that applies hot glue to cardboard. The cardboard is moving pretty fast so I need fast acting guns & associated equipment. We have an automatic glue gun that we often use with a solenoid that claims to be able to cycle 8000 times/minute, or 133 times/second, or once every 7.5milliseconds, with a minimum bead deposition time of 2milliseconds. How does the 2ms relate to the 7.5ms? It takes (7.5-2)/2=2.75ms to open, 2ms minimum open time, then 2.75ms to close? An alternative product can cycle 120 times per second, or once every 8.3ms, with a minimum open time of 5ms, so does that mean it takes (8.3-5)/2=1.65ms to open, stays open for 5ms, then takes 1.65ms to close? So its faster to operate between positions, but must stay open for longer once open? The outputs from the PLC are high speed, 0.5ms on, 1ms off timeline for gun 1 0 - tell PLC to operate solenoid 0.5ms, signal received at solenoid, starts to open 3.25ms, solenoid open 11ms, solenoid has been open for 7.75ms, it will take 1ms to send signal to close, so send signal from PLC to high speed output 12ms, solenoid starts to close 14.75ms, solenoid closed timeline for gun 2 0 - tell PLC to operate solenoid 0.5ms, signal received at solenoid, starts to open 2.15ms, solenoid open 9.9ms, solenoid has been open for 7.75ms, it will take 1ms to send signal to close, so send signal from PLC to high speed output 10.9ms, solenoid starts to close 12.55ms, solenoid closed so if I never need to operate less than 5ms, then gun 2 is arguably the better choice? Or have I mixed up how this works?
  22. I destroyed my soul removing the old tyres, took 500kg + of hilux weight to push the tyres off the beads
  23. Ah i thought I had entered this, will get onto it. Edit: entered Put new tyres and bearings into street magic, will ride it to work the next few weeks to make sure it’s reliable
  24. dang 13bhp, nice way to make some sweet power
  25. Yeah get a trailtech vapor, reliable speed, rpm and cylinder temp. I have a stage6 version too on another bike which is a good alternative. Over 200 degrees is into trouble territory, above 215 is super danger zone, hard riding on long straights should put you around 180-190 in the middle of summer https://www.amazon.com/TRAILTECH-Vapor-Computer-Kit-Motorcycle/dp/B07BYLJ927/ref=sr_1_1?keywords=trailtech+vapor+752-116&qid=1568694811&sr=8-1 https://www.pedparts.co.uk/product/702/stage6-digital-speedo-clocks-rev-counter https://www.pedparts.co.uk/product/1349/koso-temperature-sensor-adaptor-14mm-spark-plugs
