Everything posted by kyteler
...so long as you get it square . Weeble wobble occasional crank for different reasons otherwise. I'm sure that won't be a issue given Steelies is a bleedin engineer innit but just thought I'd voice it as a consideration.
Tuned the carbs, goes really well. Nek minit Rod through block.
Nice. Looking spangly dood.
Pictures, cunt. Sort it out.
Michael Jackson would disagree.
She's come a long way, baby. Definitely worth getting it to its usable state, without question.
Let's be honest. The hunter will never test their limits.
No part of them appear "backwards" to me. I could be wrong. Chances are the guy had trouble getting them off and then made excuses due to his ego.
It's doesn't have to be a Japanese wheel to have passed or have the Japanese standard cast into it.
Given the "PERFORMANCE" in the casting they could well be an old discontinued model from Performance Alloy Wheels in Australia.
kyteler replied to yoeddynz's topic in Project Discussion
What he said. It is certainly cool and I would be interested but man oh man will it change your available build time and duration. -
Surely it's just a minor alignment issue of the piston within the caliper. Reassembled ever slightly off of true.
Yes it would require driveshaft loops as I understand it.
I just helped a mate replace his front rotors on one the same, it has a bit of rott in the RHS sill. Not sure why (whether previous repair, or blocked drain) but worth checking the steel there just in case it's a common problem.
Castrol scheme. ...or POR15 -
Good progress man. Noice.
Quick Google suggests a G4+ is 40Mhz Dual Processor.
They look poifekt. Just needs lower to match.
Don't suit the car?
I'm glad that third picture was one of the "older fella". -
There used to be a couple kicking it in Lumsden too. I wouldn't jump so quickly onto the exclusivity bandwagon. You never know what people have sitting around in sheds. A lot of older cars are owned by older people who don't give a fuck about showing them on the internet.
Can't recall exactly but the Rangey has a mechanical release so slightly better.
It's possible that Jag uses the same kit as a Rangey. Check that out first.
Oh.. ..and the other one I've had to tow are Range Rovers.
