Everything posted by Transom
Fuel pressure gauge ... Install on high pressure feed line or on return line after regulator ? Or does it make no difference ? Seems te aftermarket fuel pressure regs have them on the reg so that's after injectors ... Any thoughts ?
Looking good the motorcycle Barry in me says that's a leaf sprung leading link fork you are building not a girder fork (girders have linkages at top not bottom) but it does look evil and dangerous so big thumbs up
what they said ^^^ and clean the steel first .. it really really helps wire wheel or flap disc get rid of the oily and rusty coating will make it way easier cool project looking superclean so far you will get a handle on the welding aliexpress has alloy reservoirs for those master cylinders in spangly colors for 1.99
Also unless you need to change the subframe for some reason why weld engine mounts to it when there are bolt holes to bolt engine mounts to?
Know some people with old halfcab buses that have the brass worm gear drive diffs they were using castor ? Oil vege based ?
Brake pad knock back Hayes push bike hydro disc brakes were so bad at dragging/sticking pistons the trick was to leave a slight wobble in the disc so it would knock the pads back for less drag/pad glazing /overheating/sticking more in a vicious circle the real fix was take them off and throw away funny I was just reading about the 350z brake issue last night somewhere else
All the reading I have done about arc eye and auto darken helmets suggests that you won't get arc eye thru the lens even if the auto darken is not working not that keen to test it out too much myself but I did google the hell out of the subject when my cheapy helmet was cutting in and out any welding professionals wanna enlighten or endarken us more about that?
Had a spewpercheap auto darken helmet didn't last was crap bought a 99$ one from a welding supplies guy on trademe in Nelson works good for price has grind setting and was in faux carbon cos it's hard to find one without some horrendous graphics these days 10/10 would trade again
Best place to get a small piece of Aluminium tube?
Transom replied to Firebrand's topic in Lower North Island Region
I have been looking for the same size does it need the bead rolled onto it to hold rad hose properly ? Bunnings do alloy tubes and angles in 1m or 3m sticks not sure if they do tube up to 35mm? yes Aliex has the joiners cheap as -
so this just passed the 1 year in the shed mark and i have been plugging away at small things trying to make sure it all fits made a cut down sump using the bowl of another sump ... it was ugly welding and looked too small on capacity and leaked like a sieve so i made mk II version deeper and with new 2mm steel much easier to deal with made 1 flat plate right thru at cut line and then made the cutout and bowl for ford v8 pickup l very minor weeps on testing and i just hit it with the full POR tank sealer system to sort that out oil filter remote and oil cooler mounted and plumbing mocked up lots of little bits to sort so they dont try to occupy the same space under the bonnet
Also if if was sold as another name/ brand in the USA then check the listings for that model on rockauto were mitzis sold as dodge or something over there?
No you buy the correct o2 sensor and tps from aliexpress china using the original part # to search and identify them then you get the correct sensor with the right range and factory plugs etc my $300 O2 sensor that was $150 on eBay was $40 on aliexpress
Aliexpress for cheap 02 sensors and tps find the oem part number and search using that - cheap just takes a week or 2 to get here
Would a fully sealed agm style battery pass without sealed box ? (Mx5 battery in boot stock not sealed from cabin)
Dereg =new cert sorry
How many abs systems have to be plugged into a dealer computer to cycle the abs system while bleeding ? A few I have heard of
For alloy - cheap oven cleaner in the can spray DO NOT leave it to sit too long. rinse off with water Scrub brush on the stubborn bits and rinse the hell out of it with water or it will etch into the alloy toxic as hell -outdoor use only -catch the runoff and kill gorse with it or something will also remove anodising from alloy
3 grinders - 1 for flap disc I wish I had room for 3 drillpress anyway nice workshop show us more please
Ah that makes complete sense
Looks pro need red paint on your drillpress filing cabinets too drill mill and 2x drills ? Why the 2x drillpress ? Different setup or just cos?
Old mini 4" is 101.6 mm old small ford is 108 wtf is 103?
Ok so since I'm about to buy a new clutch too ... What would you use to remove surface rust/glazing/oil residue off a steel flywheel without getting it ground? Wet and dry with brakekleen?
I hit it with the zapper some more -down to a couple of weeps no drips but the steel is getting too thin to grind back more looking at the por 15 sealing system and cleaners to seal inside and out
So I almost built a sump from 2 sumps and some sheet metal a passing seagull shat on it to hold it together -pictures coming to design disasters thread soon got a few pinholes I am sick of chasing - what's a good gooey solution to paint inside and out to help it hold oil???
