Bangbug
Everything posted by Bangbug
  1. Oh and thanks all, the 044 sounds good
  2. Just to repeat myself (or perhaps expand) I'm putting a surge tank in my ute, I ran lean once at 1/5 tank on a small incline thanks to some vigorous acceleration. I don't want a repeat with boost added I have a b2600i pump in a b2200 tank, the b2200 had a carb with a LP pump, the bowl served as the surge so it didn't need a constant supply. Carb tanks (and mechanical diesel injection tanks at least for the fords/mazdas of same kilth) don't have baffles or pots. The b2600 did, but I couldn't get a hold of one for a cab plus The wreckers tried to give me a diesel tank because diesels are injected.... 42km drive across town and then back So: Factory injection = pot/baffle in tank pump. Factory carb = just pickup at a low point and/or low point pick up pump. Both will work... but thems the differences. It would have actually been easier for me to add a surge tank in the end and use the carb LP pump as my LP lift pump, live and learn
  3. Must have been one or two, unless AMG just made them especially. Which I suppose puts them in the TOO FREAKIN EXPENSIVE basket anyway Everyone uses the W58 in everything.
  4. Goodness no. Quaife goodies inside. Don't think that needed explaining.
  5. The Duratec is awesome. You can get COSWORTH bits for it. So double awesome? Don't ask, you KNOW what that means. Gearbox... yes, for some fucking reason they made them different than ANY OTHER that they'd done before. You bastards! The MX5 6 speed bolts up... but it's a BIG BASTARD of a box because 6 speed. They're also EXPENSIVE... well compared to a 4 You can/should run the 4 speed. Brother in law runs one behind his duratech and that's 240 ponies worth of go on carbies 2wd rally extreme champion. And because 4 speed esky goodness
  6. Does that make it a M117? A few models ran that. http://www.trademe.co.nz/motors/car-parts-accessories/mercedesbenz/auction-893649701.htm That may be one. Try http://www.trademe.co.nz/motors/car-parts-accessories/mercedesbenz/auction-893364630.htm The star parts guys know much and many.
  7. If you never let your fuel get low then that'd work. Wouldn't want to be on boost and run short. If it wasn't turbo I'd not bother.
  8. Since it's a turbo and it has a carbie tank I'd suggest a surge/swirl tank set up. Pretty much look up that setup online and it'll tell you all you need to know. There may also be setup/how to's on here. Heck, someone may be selling one Low pressure lift pump (you may already have one depending electric/mechanical pump on z22) -> Surge tank -> HP pump for FI. The steel lines should be fine for the HP fuel. (Well mine are)
  9. Hurrah! Do it. And then report back with much vulgarity.
  10. I just adjusted my idle to 12:1ish as well, it was hunting like a mad thing before that. It's a nice idle now. I've only cracked the TB open a little for my idle which is not ideal. It's because I haven't set up any idle control and especially as I haven't set up my IACV! lol. Good chance they're doing something similar.
  11. When building for 4 cylinders there may be $500 in it between a MS and a Link now. And much less if you buy an assembled MS from Tardme The atom dropped $500 since I brought one, it's hard to beat value for money. (actually before I fitted it! DAMN IT! but at least I could claim back the GST ) If we were talking 6 cylinders or more then I'd tend towards running a MS because you could save 2k... but if I were running either of those I wouldn't be so $ concious I guess as they're going to burn $$$$$$ in fuel so why not burn some on a fancy ecu unless it were an old dog I was adding injection to..... so I guess it all balances somewhere in our minds based on individual circumstances. Since I'm a dreamer I'd love to run dual fuel (LPG baby!) on my FE-DOHC and I'm pretty sure the Atom can cope, just haven't looked at running both sequentially, I'd have to swap injector drives through a switch since running LPG in batch mode doesn't sound like a good plan. It has the G4 (or now G4+) features which are pretty amazing for multiple maps etc. If I were choosing between the two then I would read both of these. http://www.linkecu.com/support/documentation/g4-engine-management-documentation/G4Install http://www.megamanual.com/MSFAQ.htm The next gen of Fred's stuff looks pretty good, I still have a spin 1 Puma which is......... well it fires up but I haven't populated it. It's not too hard I guess on skill level, but you need time AND patience which are much rarer commodities nowadays If I don't give mine away I'll finish it when I finish the electronics room/office.
  12. I'd like to run bigger than std injectors in mine so I also say all good.
  13. I have no clue as to the Alpha-N. I assume you only doing it because ITB? Don't trust a mean vacuum reading? I'd do it that way, just adjust my tubing until I got rid of the spikes/pulses. It's not like everything is always perfect across an intake in a plenum either and you take a mean reading from that Sequential vs batch = not much difference performance/efficiency wise except at lower rpm/throttle application. I'm going to do it just for shits and giggles and wouldn't an LPG TURBO BE AWESOME!! Said the dreamer. Link over MS? Because MS pretended to be something they're not. I don't like some of their materials and some of their features and Link is supporting Kiwis doing ECU stuff! Yay! Even if they stiffed me $500 My write up on Link has become the official "how to" on modifying high level tacho's so I'm pretty happy about the peer review and forum there. The resale will be good. The build quality is good. The loom is good The support is good. The info is good.
  14. That is an excellent and humorous write up! I suppose the solution to the spokes would be to make sure they're a complete weld then chew out the middle ||___|| so you can wrap through them. Looks fantastic! Kinbaku expert! No wonder you have a wife
  15. yey, FE-DOHC! If you're awesome you could maybe get a Jaguar... how DIY are you? CAS + Trigger is what I will be running also. Depends on resolution of both trigger and CAS. I'll probably just use the CAS to synchronise where in the 4 cycle it is for sequential. My opinion = MS < Link.
  16. Pfffft, CSI. Lights and shit. This is OS, you need a delorean and just go back and read the number
  17. That is a great idea.
  18. Hardly androphobic. Far more Slavery theme I thought. And they were "clean breeders" as opposed to "sex slaves". Which is like breeding the biggest strongest slaves. I suppose their slavery was based on their gender above their health, but everyone else was a slave too. Can you be MORE slave? Sounds like a premise for a metal song. More Slave than the Slave. Made for an excusable premise for a giant car (war machine) chase movie either way It was awesomeness.
  19. I'm in the pub. I have my name badge on. I'm rather drunk. I recognise no avatars! I have name badges for you all!
  20. Doug and I will be at an establishment. One of them, at something o'clock. I'll look for ya'll before choosing.
  21. This is where I am. A9 - A10 See you there!!! I suppose I should wear a "Hi my name is:"
  22. I'd love to dress up, but I have no time for such shenanigans Don't let that put anyone else dressing up, I'll help polish the leather and silicone the tyre armour. Are we booked in or are we making our own bookings, who's leading the charge on this? We're running outta time! Flick that switch!
  23. Circle lounge or povo spec? I could go circle (or whatever they call it) as I'm old or something excuse worthy
  24. square
  25. Mate of mine is keen, so book him in too. WOOOOOOOOOOOOOOOOOOOOOOOOO!!!!!!!!!!! MAD FKKING MAX!
