Everything posted by Mof
Hey now I've learnt something too "The effective length is a measurement of the entire length of the Micro-V but it is measured at the cord line versus the outside circumference of the belt" http://www.mechanexpert.com/how-to-read-a-micro-v-belt-pk-number-a-technical-tip-from-gates/
+1 for twin stacks and snorkels
50/50 weight distribution, practically a race chassis
I think it's a Nissan thing, Nissan Diesel did that too on thir trucks of about the same era
Wat My correction bushes have been in for many years. Blardy landroverses
Mof replied to CarolsHusband's topic in Other Projects
1kz 13bt 13b -
I'm glad you're getting somewhere with that engine, because I got nowhere with that parts one down here
You'll have to walk around to both sides to release the pins anyway?
Can you cut the groove a little wider?
It's good to have that centre bearing a little off, 2-4º. It'll make the uj bearings at the box do some rotating. Centre bearings are never spot on
Condenser?
Credit to @Nominal Pull dizzy, turn one tooth, try again. Rotor should be pretty solidly pointing at #1. Remember, the plug fires at just before tdc. Hence BTDC There should be timing marks on the crank, and cam gears, to get them lined up properly
@ajg193 me also please if you don't mind please and thank you
Electrolysis - brass plug should fix that. Cavitation - a cavity behind the plug creating air bubbles, is the plug in deep enough? Coolant mix (but I doubt it) - no more than 50/50 mix, 30-40% antifreeze is best. Too much af to water can be acidic.
Got a pic of the old one?
#6 should be coming off exhaust and onto intake (rocking) when #1 is at tdc fyi
Will find out
Is there supposed to be a copper washer under the head of the screw?
Driveline down here just took a turbo td42 from the workshop in bits. It dropped #4 liner, but depending on yours you might make 1 out of 2. I don't know what their plans are for it but they might be happy to move it along. Dream build btw, love it
Are wider offset rims covered by cert? Thanks
Hello gents Is there a way to reduce the power steering assistance? I feel it's just too light. Cheers
You said oil pump, do you possibly mean fuel pump? As the oil pump would be in the sump
@spanners
@h4nd I could. I think I just dodged going to ashvegas. @NickJ will you be attending?
