Everything posted by locost_bryan
Could skip it, it's only food trucks and wanker beers in a downtown warehouse. Do we have a venue?
Bugger, work Christmas do on the 18th.
A lot of cars have privacy glass from new, so you're tinting tinted windows.
It’s a Vanden Plas Princess 1100 my good man
locost_bryan replied to Agent75's topic in Project Discussion
Autocar road test from 1 Jan 1965. https://www.flickr.com/photos/triggerscarstuff/albums/72157646375923746/with/14907323742/ -
locost_bryan replied to Roman's topic in Tech Talk
Commonly used Whitworth or B.S.F to SAE / A.F (inches across flats) sizes and conversions to metric and decimal inch dimensions. http://www.baconsdozen.co.uk/tools/conversion charts.htm -
Good source of ADO16 info and parts https://www.facebook.com/groups/ado16.info/ -
Very nice. The Americans might have invented the drive-through, but the Brits invented the cupholder to make it civilised. -
Wonder if it was an Embassy car between '65 and '71? I think they had special plates that were assigned to the Embassy, rather than to specific cars (I could be wrong). Lovely car, great project. Have seen a few recently on the ADO16 facebook group. -
Quietly sporty system to suit '70s Pommie four banger with 100-120bhp - 2" pipes big enough, with a couple of Coby-style mufflers, or a two-box at the front and a resonator at the back?
If I replace the original static 3-point seat belts with inertia reel belts using the factory-fitted anchor points, does that require a cert? (Pretty sure someone's asked before, but search didn't find an answer)
Possibly worn trailing arm bushes or the pivot pins, never had that happen to mine, but think I've heard mention of it causing clonk sound as the arm moves under weight transfer.
A poster on JalopyJournal.com commented "sent them to Barry at Autolign in Christchurch . Rebuilt and back within a week" https://www.jalopyjournal.com/forum/threads/lever-shock-rebuild-down-under-nz.1079345/
Nice car. My sister had one back in the '80s. Do you have the original seal, or is it missing? Basis in Blenheim would be a good starting place for rubber seals https://basisnz.co.nz/ - they don't have the 16L listed, but they really know their stuff. Listing for seal 322.030 here http://www.scottsoldautorubber.com.au/MITSUBISHI CHRYSLER GALANT GA-GB-GC-GD 1971-77.htm Same one is mentioned for GTO boot in this thread
Reading between the lines, the Tasmin changed considerably over its seven years, as the Ford and BL donor vehicles changed, and the online discussions amongst the Wedge enthusiasts suggest there were a few variations of the wiper arm length and shape. All part of the fun with handbuilt cars.
Found a parts catalogue online, although it doesn't give details for the wiper :- https://www.theseacpages.co.uk/media/wedgemanual.pdf Always liked the Tasmin.
Re the wiper arm - Mk3 Fiesta 1988-95 - discussed here https://www.pistonheads.com/gassing/topic.asp?h=0&f=12&t=816540
Probably. Iirc, it was tucked away down on the gearbox and they had to remove some the engine plumbing to get to it.
Yeah, brother-in-law just had the trans control unit replaced on an early Mazda 3, gave a similar code, occasionally wouldn't change up from 3rd, but would run normally after stopping. Took a while for the problem to get frequent enough for him to note the circumstances/pattern to describe it to the Mazda workshop.
Karol Shusbands 72 Skyline. Discussion.
locost_bryan replied to CarolsHusband's topic in Project Discussion
It's the Old School stamp of approval. Now, what were you talking about before someone said "LD28"? -
P76 4.4 V8 and Borg-Warner 3-speed manual (or P76 2.6 SOHC inline-6 and same gearbag but column change). -
Sorry, meant to say search the engine number, not chassis number. If you're lucky and it has the original engine, and the number was recorded correctly...
The NZTA still have the details for cars that were still registered when the records were computerised, but that list only has the live plates. You might have to contact the NZTA and pay for a search of the chassis number. I have a similar issue with lapsed rego - carjam brings up the rego details, but the chassis number is not in the NZTA spreadsheet. Fortunately I have the black plates and the chassis tag matches, so I can go through the re-registration process.
I like them. On the NZTA website, there is a downloadable list of pre-1990 rego details - iirc engine and chassis numbers, colours, rego date, body style, but not plate numbers. https://www.nzta.govt.nz/resources/new-zealand-motor-vehicle-register-statistics/new-zealand-vehicle-fleet-open-data-sets/ You could probably trace the engine number for Avenger wagons registered between 1975 and 1977, and then ask NZTA to trace the rego number and tell you if they had both been owned by the same old dude.
Good ones seem to be $5,000 to $8,000. A bit more if really good.
Is it that time of the month already?
