Everything posted by Tumeke
Spring clean. Before: After
- 13 replies
- 16
Further to last update I finished (roughly) the fuel pump setup last night: FUEL PUMP Take one piece of aluminum off the side of a broken welder, cut it into shape, cover it in kids dura-seal and drill some mounting holes. Whip out Ali Express's finest (cheapest) Riv-nut gun and slam in some captive nuts unlike everything else British. Re-purposed the old fuel pump bracket to hold the pressure relief valve. More captive nuts and a coat of whatever paint I had lying around. Complete setup installed. Factory pre-filter on the left (with new filter) - Bosch fuel pump - high pressure filter - pressure relief valve - metering unit. Not the tidiest solution but wanted to re-use a fair bit of what I already had to keep the cost down. This will be coming out again to weld up an exhaust mount underneath the floor and i'll blast some paint in there at the same time.
- 13 replies
Updater. 1. Fuel pump. The one on the left is in the bin. The one on the right is in the boot. We now have reliable Bosch fuel pressure at 110psi at all throttle openings. New power supply and relay fitted also. I'm just finalising a mounting system and I'll take a pic for the next update. There are kits on the market but they are very spendy so have put something together myself. The original Lucas pump is actually a windscreen wiper motor. Needless to say it wasn't a great option from new. 2. Metering unit. After many many hours fettling, dicking about, trying things, trying other things I decided to rob a bank and buy this: Stuck it in, timed it. Available for sale for a limited time: Patented Tumeke injector bleed test bed © Also available Tumeke Remote Cranking / Gravity Weight System © Also reset and re-sprung throttle bodies, butchered a twin cable choke cable (if anyone has a spare I'd like it please), fixed the over-drive switch with some re-wiring and generally dicked about. Pretty close. Still needs a bit of timing / tuning but mobile and has been moved to home garage rather than storage garage so that I can begin cutting out rust for a WOF. The saga continues.
- 13 replies
- 19
I'll bring the Buick Humber, or the Wolseley 6/110 or the Triumph 2500 Keen.
@kempy knows all the stuffs?
yeah i'm keen date dependent.
Repairs and repairs wagon. @cletus "M9 - no hunnits till that actuator rod is connected boes" Holden ute accidently parked across two parks. Can't think why. Delux job Forgot to take car pics but here is that Zephyr estate trips crabs raymond mays conversion that was there. One pic's better than none etc.
Yarp. Keen if the weather plays the game. I'm in Papatoetoe - not quite Puke but not quite the North Shore either.
Election 2017: OS Meet location
Tumeke replied to Threeonthetree's topic in Upper North Island Region
Just needs a mate a bit like- 63 replies
- business meeting
- have your say
(and 1 more)
Tagged with:
Yeah that's what I meant. and that blue Austin Cambridge estate. #mybad- 63 replies
- business meeting
- have your say
(and 1 more)
Tagged with:
Good turn-out last night - I now now have a 635csi and a Prince Skyline on my ever expanding want list. I'd be keen to try the same venue again next month before crying too much about the parking - I wonder how much was School Holiday tax? Also the GC from Burgerfuel said he'd accidentally park his ute and trailer across a few carparks next month if we wanna try again. This has nothing to do with me winning free fries after playing burger-pong. Who am I kidding. Free fries motherfucker!- 63 replies
- 6
- business meeting
- have your say
(and 1 more)
Tagged with:
Pointless update: On the way to Nat's I noticed a pretty bad brake judder at highway speeds and thought I should 'prolly do something about it. Diagnosis by default was warped disc etc, however, to eliminate this I pulled the handbrake (Gentle, Mavis...) at highway speed and got vibration. So, we have rear brake issues. Upon a bit of inspection, it appears the design of the Buick mag had a slightly different dish than the original steels, so it was clamping down on the drum outer rather than standard lug grabbing points. Two options to remedy - pull of drums and machine down high points - which would be nice If i had a mill - and due to the high points being the outer balance points (and balanced by drilling) I didn't want to hit them with an angle grinder in case it made the balancing worse. The easy way out was to get a 3mm alloy spacer. RAGE (Rough as Guts Engineering services) at your service Ma'am. Of course, easy is relative - the one's on the tard didn't fit the prescribed 5x127mm (5x5") so I modified some others I had lying around. Joined the Humber club a while ago although hadn't done any events with them until a couple of Sunday's ago an opportunity came up to do a drive to Manawhai via SH16. This fitted in quite well after Caffeine & Classics and I was already over the bridge so thought why not. By default I was certainly the whipper snapper of the group by a couple of decades minimum - however great sharns all round. The trip north was best described as tortoiselike, maxing out at a heady 80km on the downhills with a constant cloud of blue smoke on the over-run from all parties. Lush. Had lunch and a cup of tea at the museum then visited a beach and did skids. (One of the previous things didn't happen) My favourite new Barry was Mavis (Ann Dimoline) who owns 9. Have a read about her here. The current compendium, each nicknamed by Ann, reads: 1965 Humber Sceptre Mark I (Opo); 1966 Humber Sceptre Mark II (Pearl); 1961 Hillman Minx 111b station wagon (Chanel); 1962 Humber 80 111b station wagon (Toto); 1963 Hillman Super Minx saloon Mark II (BT); 1966 Singer Gazelle Series 6 Auto (Tommy); 1954 Humber 10 MK 7A (Babe); and 1974 Commer pop-top camper (George). What an absolute battler. Anne to the left with her Humber 80 Wags named Toto I bless the rains down in Africa - Gonna take some time to do the things we never had and collection of swarming Barrys. A fave to be sure - what a great wag - and a daily too - loaded with tools for Robertybob Handyman services. Otherwise no updates right now, however I have a couple of subtle upgrades in the pipeline, however a few other projects on the boil means they may be in warmer weather. Otherwise long may she continue being a workhorse and doing what car's are meant to be doing - driving and stuff. Yesterday delivering latest 'investments' to storage for even more future work. Peace y'all.
Daym. I'd be keen if not at Hamner :/
Twas a Super Minx. I pulled the door dent out enough for him so he could put his window up. Unusual, as I thought Mustangs usually crash into crowds.
I'll bite. How much?
Auckland Monthly Meet - 21st June 2017
I'll be there - but have mismatching tyres. Got the burn-out tyres* on the back y'all. *T's & C's apply,. Burn-out only possible if someone covers the carpark in a thick coating of lard, ky jelly and pamolive dishwash. Burn-out will actually be a combination of wheel bearings, tire rub and clutch exploding. Credit criteria and a $99 dollar booking fee apply. Goes hard for what it is. Cut cat M8. Like a shit on a rail wrapped in blanket. -
http://www.trademe.co.nz/motors/car-parts-accessories/personalised-plates/auction-1347006420.htm I read it wrong.
Yeah I'm thinking of popping it for a gander - weather dependent etc.
Aucklands I NEED A HAND working bee threads
Tumeke replied to Shakotom's topic in Upper North Island Region
I'll try for the Sundee arvo Kempy - as long as it's not pissing down etc! -
- 9032 replies
- 15
Shit yes. Awesome. Planning on using your services a fair bit once she's running - seen what you can do with throttle bodies - awesome result. The whole engine bay looks like the Exxon Valdez used it as a port for a while .
Small update - trying other stuffs: As previously mentioned, engine is running rich enough to kill a set of plugs in a few minutes. The metering unit requires vacuum to control fuel supply. Not enough vacuum = rich. There are three throttle bodies, each used for vacuum supply. 1/2 = dizzy advance, 3/4 = metering unit, 5/6 = vacuum reservoir then to brake master via one way valve. For those playing along at home, the screw on the end is the idle control. In/out etc. You can check if your butterfly's are closing correctly by jamming your finger over it. Stall = good. So, checked throttle bodies for leaks, including balancing pipes, other pipes etc. All seemed ok. Possibly small shaft leakage but I'll leave that for now. Threw a vacuum gauge off a T inline and got a bouncing reading under 6hg. Not good. Factory says 10-12hg. Checked other throttle bodies - same deal. I'd previously checked the tappets with @Threeonthetree and we reset to factory 10 thou just the other day. Then it struck me - has someone put a more aggressive cam in this? A bit of research suggested it might have something like a Piper fast road cam. Opened up the top and changed clearances to 16 thou. Reconnected vacuum gauge and what do you know. 12hg. God knows what cam i've got - this is gonna make setting things up more interesting Anyway, now with the correct vacuum the metering unit has the prescribed travel on the control link (see previous post for pic) but, alas, it was still running too rich. Had a think about adjusting the xmas tree of fuel delivery on the metering unit but knew this might be a tad out of my skill set so tried something a little more creative. Knowing there was likely some wear on the follower and control links of the metering unit, I decided to sacrifice some feeler gauges. Warmed the car up, and slowly started increasing size between the follower and roller on the control link until maximum idle was achieved without stalling the car - the theory that this was backing off the fuel cam. Got to 18 thou and found what I assumed was a sweet spot so cut the gauge in half, stuck it in the metering unit and road tested. Findings so far : car not as rich at idle now = win! Car now has no top end pull = lose. Next steps: Back of the gap a bit more between the control roller and follower and try and find a compromise between idle and full noise, check ignition advance, play with fuel load fuel setting screw. PI Lyfe.
Lock it in Eddy. (Mr Vapour) No probs -
Lil more progress however she's running oh-so-rich - to the point that I keep fowling plugs / black smokes. Been through a few plugs now trying to diagnose. I reset the max fuel screw to factory spec on the metering unit and fluffed about with trying to balance the throttle bodies. These could do with a bit more work, but I don't think they are out enough to cause this kind of enrichment. Also, overfuel/choke lever is resetting per guidelines. Blew the over-fuel return clear with the compressor, and then checked for vacuum pressure to metering unit - which seemed a bit low - however I might have also fowled a plug in this process. Did a compression check and all around the 160 mark which I would consider healthy. Did a dort sans bonnet up the road So, next steps (and yes - please comment/suggest) are : Double check ignition side - try another coil in case it's weak, replace/clean plugs again, test lead resistance,. Vacuum to Metering Unit: more vacuum diagnosis across all three sets to see if any difference with side of metering unit to check travel. Metering Unit: Double check fuel pressure with another gauge, then if that all turns pull metering unit again, replace all seals / rebuild and/or start playing with calibration adjustments under top cone of metering unit. (I don't want to do this.... see below) Also - all o-rings at both injector end and metering unit end could also play into problems.
Spent some time on the weekend with the help of @kempy with good results. Some of the stuff I remember: Changed one-way valves on injector pump, cleaned points, bled injectors, replaced injector, adjusted fuel regulator to 110psi pressure, cleared return line, adjusted overfuel lever, replaced 6 (yes 6) totally dead spark plugs, re-timed and marked ignition, swapped distributors, lost all the hair on my arms and temporary hearing whilst fireball from backfire on intake gave @Geophy and @Threeonthetree a good laugh (possibly due to me holding a can of engine start that was also on fire) and then started car. Next steps - sounds like slight miss on one cylinder but no cooling system plumbed in, so, reinstall radiator, tweak, and do skids / road test / fix all the other stuff I find broke. Finally making progress = win.
- 13 replies
- 17
