64valiant
Area Reps
Everything posted by 64valiant
  1. oh yeah this was no dig or anything at anyone just a assumption on what was happening with current situations and replying to kims post. I personally was happy to help with the meets myself and let Marku know when talking to him but he didnt want me doing them anymore and made that pretty clear. myself with the new born i haven't really been attending as my life has changed a bit and other things come first these days. I remember when os was doing them at the base it was just 5-7 people around one table at burger fuel, hasn't really been a big number thing from when i started going to the monthly meets myself, but when we opened it up to public and had a regular location and date we seemed to drag more out due to larger interests and different vehicles to gander at. I'll keep watching for events and locations to see if i can attend them when time is available.
  2. that was for last months meet and they are a closed event and invite only these days, no one has made one for this month so far that i have seen. usually would be this thursday been the 2nd to last thursday of the month, but mainly cjc people these days since going to new style of meet by the sounds of it.
  3. Hi. lets go back a few steps. I had just received my beam from Sean at kune re. I put a few layers of brunox on it and painted it black. and stashed it away. the next stage was to fill some holes and touch up some rusty peaces and i was waiting on a mate for a hand with this part but i ended up getting a bit impatient and smashing them out with the mig welder and cleaning them up with a grinder cause im clearly not a welder and while i was at it i went over a bunch of my old welding peaces and ground them up and cleaned them up. a few late nights and got the job done. next up i wanted to cover the underneath with brunox and get a few layers in to convert the small amount of surface rust it had and set a good base. with that done i went around and chucked a bunch of seem sealer on crap to clean it up and make sure aint no water getting passed my dodgy welding techniques. once that was done i dusted the under body with some underseal. end result was pretty much brand new. next job was to get the beam in the bus, i needed to put the steering arm and the torsion arms on. this also meant i needed to shorten my leaves to now match the narrowed beam. to have them narrowed i visited a mate who helped me cut them and he welded the ends together to make the leaves go into the ends easy. here we cut. here we weld then i kinda rounded the edges to help it find its own way into the hole and re drilled my locating hole for my arms to bolt into. next up the torsion and steering arm on the beam next job to put the beam in, and jesus i am lucky to have a hoist. me and @flyingbrick lowered the kombi down over the beam and bit by bit we went up and down with a peace of wood between the beam and the ground as the fitment was so bang on with my underseal on it she was binding up going in, definitely should have used lube. but we got there in the end beam in, the brakes went on the front, new rotors new bearings, new calipers, the only 2nd hand part here is the drop spindle and the retaining nut which was robbed of a bus rotting away. this wasnt an easy job. i ended up using a strop and tightening the bottom arm and kinda fitting the drop spindle in the middle now with that all done i installed my gear linkage. i replaced the bush at the front while it was out before i went and installed this next up was the rear. for some reason i was doing this all to fast and didnt really get many photos of assembly. but the new stepped spring plates are a breeze. actually after that i had to put the rear arms in, which i had replaced the bushes in quite some time ago and they were ready to go. so also installed them after the spring plates. next was the rear hub, i actually drilled my old one out to fit different bolts in for the horse shoes i tried to fit just before covid last year. so i got some second hand ones and headed to evans place to use his sand blaster and clean them up. before: note the long noes pliers as circlip pliers during after and new bearings fot the rear hub section. now with this all done i can put the axel in and put the rear brakes on and continue doing small jobs. next up was new brakes lines, hard and soft ones all the way through the bus. also my last slave cylinder was just left sitting out, kinda rusted and also never really worked correctly when installed on the bus. so got a new one of those but the cups where a different size than the last one, so got some small adapters to make it work also i had replaces both hand brake cables, accelerator cable, clutch cable and complete full axels and cv's some where along the line. This where i ended up in the last post. made it on the ground and drove it for the 1st time in over a year. Great success. one Greg for scale i just checked dates on this and i started grinding the under body and doing rust on the 12th of feb and she was on the ground out side on the 23rd of feb at 830pm.
  4. Ahhh 2021 is here now. I see Ben in his impala here already. Who else has arrived for the full event.
  5. Hi team. Its been a long time since the last post. Just thought I'd let you know most of this is back together and i have maybe 5 things left to do before i can drive it. Life has been a bit busy but i'll write up a detailed post when i have a few extra free minutes. keep safe
  6. I'm going down to see Karl today at the place that done your injectors if you wanted to pop down and talk to him not during work hours about your options.
  7. mine is for business advertising reasons really. main street for talking and max profile of people viewing the shit i have. (eg rotary beetle) you can cruise the main street at night when ever but say you head to a viewing spot you might find it hard getting a car park to view but if you are an entered person they always have car parks there for you.
  8. Hi. this is me showing my interest in the event. will check back in once i have a small human and see what my life says about going away for a few days with the BOYZ
  9. 2021 entries acquired. this time ill attend
  10. Came up on my fb memories that I posted photos of such a great event. I look forward to attending next year. Siting out side the rsa talking to locals riding there horses for the arvo. A solid 10/10
  11. ah i had seen that done on some other cars before @RUNAMUCK. i hadn't thought about how i was going to lower it as of yet other than i really wanted the rear to tuck a little more and that seems like a god way to gain a small amount.
  12. do you still miss doing clutches @Evan?
  13. Hi team. Long time no posting, since my kombi wasn't really going to be going for summer i thought i would get this on the road. well i had thought about it and then a mate asked to use it for his daughters school ball so i ended up splashing out and spending some money on it and getting a wof. the wof fail list was - speedo not accurate - rear door latch missing bolt - fuel leak in tank - Brake light switch to secure - high beam light in dash not working - front seat LR to short - brake shoes worn out - brake hoses toast - rear bump stop missing - front bump stop worn out - RH outer tie rod end worn - Pitman arm joint loose - LF wheel bearing toast - idler arm bush worn - carburetor missing bolt his one recommendation was to raise it LOL and here i was wanting to lower the rear a sly 20mm with the deadline of this week i said to go ahead and just do it all him self. 3 days later now and i have this There are a few things i actually want to do but with the kombi been on the hoist and been away for the weekend made it so much easier. after destroying my last set of tyres at the wedding i had been offered the ones that are now on it for a cheap price and they are 245 60 14 just a bit wider than the last 225 60 14 so thats the reason for the rubbing in the rear. will fix that with some smaller tyres and maybe lower it another 20mm in the rear talk about why i should use it more often and that your glad i got it going here
  14. No stress at all. My post certainly wasn't as informative as my previous posts in the thread. Have been going through and uploading photos via flicker as all my old photos have managed to fall off the internet.
  15. @Roman my kit for the front beam has a bunch of extra bolts in it so it can be raised 40mm to add more slamm i would need to remove the vivid mark of steel out add more steel and weld it all up. you can see the height difference in this image from the bolt holes to the top of the modified one and the one not modified on the other side this is from the company who supplied the kit
  16. so the rear plates allow it to go lower, from factory they are straight the notch in my ones allow drop instantly with out having to change the spline to much. now it also has two plates the main one is the back one and the front one has the spline in it. you can adjust the height by screwing in the bolt getting it with in mm from side to side, or you can lower or raise it 20mm. the other laser cut peace that looks like a horse shoe helps space out the dust cap allowing for the extra thickness in the spring plates ill do a video and post this which might make things easier explaining front front beam is now 2 inchs narrower as im going to be running drop spindles, drop spindles usually space the wheels out wider so by narrowing the front beam im able to run same offset wheels and not have them stick out more than needed. (i also like the sucked in look) a factory beam has his bulky end on them by cutting them off and putting a 10-12mm plate on the end you are able to bring the track in a bit. most modified beams are done like this and if you run the likes of Porsche disc brakes they space them out wider again. this is a 4 inch narrowed beam for a early kombi and you can see its much the same design as mine picture of a bus with the wheels sucked in. this also helps with steering when the bus is super low. side note. on beetles the wheels start to hit things and its the only way it works narrowed beams
  17. Hello. turns out i purchased a front beam for a kombi that was suited for 68 bay window and every split window bus. this kinda bugged me as i had already put adjusters in it and the bolt holes didn't line up. so i remembered i could get a kit from Fresh Kustomz in aus which i could install myself. i priced it up and i was also trying to get a rough idea on price from a chch company on what they would pay for my current beams. they became a bit difficult to deal with and in the mean time i clicked a buy now and i had the kit from aus in a few weeks. the kit is a 40mm raised beam kit ofr a early bay window ball joint beam. It comes with 2 laser cut ends, adjusters and stays to help the beams strength. i was going to do with myself with the likes of @bobby1930 and @Geophy but all our lives are rather busy and trying to get all the stars to align was a bit harder than expected. so i hit up @oftensideways to see if he would be keen on doing the job for me. discribed what needed to be done and he said he would be keen. the following weekend @Mrs 64valiant and myself headed down to drop the beam off. watched some bathurst and caught up with Jones family and meet a few of there friends over a bit of a bbq. a few weeks goes by and i know Sean doesn't really muck around when it comes to jobs so i flicked him a message to see how he was getting on. received a few images back of it all mocked up on his welded table and starting to come together. he said it would be ready the following day so i said i'd head down on the Saturday coming. So off i went for a drive to Ohakune. and now its Monday. Super stoked! well worth the trip! next on the list. I wasn't happy with the fitting of the horse shoes i was given for the rear suspension. so i was after some dropped adjustable plates. I had been trying to get some from a local supplier and we were not having much luck with all of his suppliers and i mentioned type 2 detectives, he had heard of a few dodgy stories from the company and didn't want to buy the product which is fear enough. I said i would. it took me a while to get around to doing it. ended up making a call on the 4th of this month to the company over in uk somewhere, was really helpful and put a link in a email address and i clicked the purchase and it was sent the following day. i had been tracking the item and was suspicious with how long it would take to get to nz. turns out it would be 10-12 days. not bad at all. and this leaves me here. i really wanted this back on the road before beach hop and the new arrival but main goal now is to make some solid progress and get driving again.
  18. Bloody rookies over here It's Karen here "I'd like to talk to management about this. It's not acceptable" haha.
  19. Hi @MopedNZ would you be able to fire me the event form for entry please and thank you. Would be muchly appreciated. Cheers from one of those speedcocks.
  20. Pretty much underlay. They might have a bit more movement in them so not that stable/rigid. If you were to ask me what I would actually recommend, i would say go buy some from an upholstery shop. I sell it for $50 a meter at 1.8 wide. You won't need 2 meters for a car or 1.6 for a ute, pay cash for a peace the guy has had under the bench and get it a bit cheaper.
  21. Going off the Auckland business cards on the desk I would say not?
  22. I have used house foam underfelt its quite nice easy to cut and doesn't really soak up water. Changed back to thick traditional underfelt just sits better over all. Also easy to get from my suppliers and used on a bunch of other things. Either works just as fine.
  23. Usually he doesn't do it. Just gets one of his plebs to do the running around. Well that's probably why he can travel 2.5 hours for that stuff. If anyone wants lessons I'm sure @MRWEST can pass on brodies number. (inside joke)
  24. Oh yeah can't wait to see it painted Matty B @MRWEST
