chris r
Everything posted by chris r
  1. 17k is the insurance valuation so I'd like that for os peeps. I'll chuck it on the tard for 20k
  2. Went to nats and back. Blew both donut gaskets on the manifolds and was pretty much open headers back from Huntly. It did some awesome flame shooting after overtaking people. Gaskets have been replaced now. I am looking at selling this soon, will be heading to the states In Sept and want more toys. I'll get some estimates on re doing the white paint ad it's very thon/starting to rust a tad
  3. Or re grease all the joints in the linkages? Could be dry and binding up
  4. Alternator bearings? belt idler being gay? does it do it at varing revs when its still? Has it been lowered in its life? My shuttle has eaten the rubber vibration dampers on the cv shaft where it hits the chassis? one of these could be loose or something?
  5. take fuel hose off and unplug starter wire and hold key in crank position - done this on a few cars. Fuel pump usually 'primes' when you have key in start position so can use that to drain it
  6. That's so bad/good
  7. Yeah that'll be perfect. Battery main same and ignition feed to the sense terminal
  8. Low terminal is for light. It is not quite a earth. The top diagram is mostly correct. I will do a Ms paint pic and put it up tonight
  9. Check from sender straight to gauge)(key off) amd if it's OK all is well. If not then start tracing wires
  10. Put some photos of it up. I don't imagine the coil/ignitor will be too oddball.
  11. Loose connection/poor earth's somewhere? Try checking continuity from sender to dash and make sure the wires are allgood
  12. Going to new school buick v6 it tonight
  13. Might bring the bike no registration no wof no worries right?
  14. I have made a fre things out of pallets and cable drums. mk1 bbq table is too small so made a bigger one. Made a bar leaner and a shoe rack (which is too small now)
  15. Both my oil pumps are out of psec clearance wise so I'll have at them practicing porting. Cant fuck them any more right?
  16. I have started assembling the engine. I've done the crank and spark plug seals, fitted the head studs ,gasket and head. I've started fitting the water pump pipe and thermostat housing. Put the vtec solenoid on. I'll get some assembly lube next week and put the valve train in. The crank girdle needed a bit of grinding so the rod ends will not hit it. I shouldn't be bending/damaging those rods any time soon. I've dummy fitted the churbo (still need to sort out gaskets for it). TOmorrow I'll clean the oil lines and figure out that plumbing. I'll dig up a service manual and check out the oil pump clearances and give it a port. I have two oil pumps so I'll practice on one first.
  17. Tickled? Shit you'd be locked up if you Tickled your Mrs like that.1200 is pretty rough as a pay out. I am hoping mine gets repaired. I went into a couple of panel beaters this morning and eventual got someone friendly and helpful. Someone from alpine happened to be in on his day off and was really friendly. I'll pick up the estimate next week and go from there
  18. Open header backfiring 350 might not be popular with the neighbours. I have all the drivers details so will sort it
  19. No photos of motor yet. It got reversed into by a truck today and despite my hoarding shuttle parts I only have a spare guard. I'm in the process of getting quotes to get it fixed. It looks like it needs a guard and bumper/bumper support. Luckily there is little damage to the frame/chassis. Now I have a total of zero cars I can drive haha
  20. Widen those steels. White povo commercial spec looks good
  21. Shocks and tires have been changed since video, handbrake slides are gay with this (yes its not true 4wd) but the hand brake still wont lock the rear it just slows everything down. I think the easiest thing to do will be re drill the trailing arms to suit the bars I have. The video has a severe lack of driver skill too.
  22. Looks good! Your keen doing that work in your drive. How is the car cover holding up? My one has started to go rotten/silly after sitting outside. I wish my 350 made that power, It barely makes half
  23. Phone takes shit photos in the dark. Better wait untill nats to see whats in the back. Will be packing tools to change the alternator belt as it loves to eat them.
