chris r
Everything posted by chris r
You could probably say that with a lot of our projects really. The manifold looks bloody good. Bet it is satisfying to see the manifold all completed
Only if you don't do them properly or use the cheaper tools
25mm cable will be good. 16mm if you are feeling cheap. A good cheap source of battery cable are r33 skid lines as the battery is in the boot so you can get reasonable lengths for cheap from zebra
My bet is bad earth's too. Even it looks OK and resistance checks it to they can fail when hot. I have a crimper so if you need to re do it just give me a bell and you can borrow it
Of course I'm not going to buy another car haha. I was wanting the factory airbox more than anything. I'll need to do more work on the rest of the fleet before I get balls deep in this
@66gt Funny thing is I'm pretty sure My great uncle smoked too. They had their priorities right though and spend coin on a LSD. Unless it was factory fitted
my vote is throw a chevy in it. less headache than a 1uz, and mounts are cheap
I should buy this rx7 and use the motor in mine until it goes bang. What I am most interested in is the factory airbox though. oh and ness has decided she likes the sound of a bridge port. I told her she can buy the porting template and I'll have a go at it
I've fixed the first post so the pictures actually work now. I've put the radiator support panel on and started bolting everything up. I thought I probably should turn it over since its been sitting for so long. With glens help I chucked the battery cables on and it fired up with a good dose of ether. Thats probably going to be all I do on it for the next few months
x2, It looks heaps better now
Does it do it all the time? Give the airflow meter a clean. Try unplug it and it should go into limp mode and be down on power but should be smooth. Or another thing could be low fuel pressure/flow
2 Trailer Loads of Death... Mostly Gyro X build thread
chris r replied to Raizer's topic in Other Projects
Same here! I can't think of a more fun collection of things to kill myself on -
I fitted the spring today without too much drama I also replaced the sway bar bushes too. The lights turned up from aliexpress last week I mounted them today and ran out light so I'll wire them up tomorrow
fuck yeah, please tell me you are going to get ali express injected IDF bodies
I think that is some of the problem. I'll bung the camera in and check out that area again. The coating does look pretty thin on the bottom of the tank so who knows. not really, prior to the por-15 I had been fucking around with the electrolysis and it has many many rinses cleans before the por stuff went in. Unless I couldn't get the metal ready to every surface due to the baffles etc
No idea. There seems to be heaps of little balls which are soft until the fuel evaporates? Either way they have blocked the pump pickup filter and there are many more of them still in the tank
Today started off well with the tank in the crx... The theme continued when I attempted to bleed the brakes on the van. I got fresh fluid to the drivers rear all ok, then when I took the cap off to top the front reservoir up and when the mrs pressed the brake it sprayed everywhere. The cap went back on and the passengers side went nicely but then the drivers side bleed nipple snapped off. For the sake of $40 ish us I'll get a new master cylinder and I'll take the caliper off and give it to someone else to wreck.
Another update. I don't know wtf is going on there possibly some of the coating is failing or coming off?
I took the leaf spring that was damaged out and dropped it off to archers. They have repaired it and it's good to go, ill have to arrange to get it collected next week. If I remember rightly it's about 70 plus gst for the repair. I'm stoked with that
I've had mixed results with the supplied caps on china rads, most of them have failed or been shit on arrival
That is cool, basically a newer version of the 74141 ic
I am intending on using the 74141 driver chips. They need have 4x inputs high or low 5v to display the required number. Most nixie clock kits using arduino or found don't use said chips
Neither can the Mrs puukuu I got a arduino starter kit ages ago. Dies anyone have recommendations on learning how to code? I want to make some displays with my nixies at some point.
Election 2017: OS Meet location
chris r replied to Threeonthetree's topic in Upper North Island Region
Mayte the throttle is pinned just go 80 don't need to chop any gears- 63 replies
- business meeting
- have your say
(and 1 more)
Tagged with:
