hillman1
Everything posted by hillman1
Sweet that's what I was thinking defiantly called starter signal on all wiring diagrams I can find just wanted to double check before hand to save from posably frying ecu
Just curious as to the best place to get starter signal from is for ecu ? All that's stoping me from going back to efi
What a prick of a person
You will never find a mint hunter dash I have been searching g for 5+years for one gave up a d made my own
Those adaptor kits genraly are cheap shit with bad port spacing
If that's on 13s I'd say that's a 3 to 4 inch drop if I get time ill measure my springs up which are just captive on standard shocks can't quite rember if they were lows or superlows
I would be looking for leaks around the bottom of the windscreen usaly where they start leaking from grab a magnet and look for bog
What's the easyest way to upload pics I can't work it out lol could show you wheel figment ect
13x7 will fit with rolled guards and a 185/70r13s was a close fit of 13x8s with 205/60r13sbut couldn't roll guards enough with out ruining factory lines of car only needed 20mm more clearance tho
Pretty much easyest to find will be out of a hillman hunter bust run line from master cylinder and vacume line
Really depends on your taste easy to lower get a set of dobi superlows they are just captive on standard shocks and reset leaves with 1inch blocks has mine siting level ideally you will be looking for some sidedrafts or be thinking of a motor swap as the 1725s are not speed demons standard diff can take a beating nice wheels can be a hassel if you want a modurn style being 4x108 stud pattern but moddgies or tridents or turbos suit them great in my opinion I would t go over 14inch wheels any bigger ruins the lines or them got a mate with a sr20det hunter great I. A straight line ducking scary around corners/under breaks they do t need huge hp to be fun
Haha my first 6 cars were hunters lol
Oh mate ill double what you payed right now lol good score
I'm Shure that's still how they test them at most places isn't it?
Out bid $300.50
The mrs sister has got one for sale ATM newer model ssr surf with lift kit and big tyres ect ect she's asking around 4.5k ill get more details if you are keen on it mate its pretty tidy in the body work side of things apart from paint fad but pretty fair to say it hasn't had any serious offroading before flick me a text if intrested 0221245460
Ill be walking from my place like 1.5k up the road lol could t sus carbs out in time floats still sticking and can't get single carb mani to seal up properly so I give up for the night
Yea mate will do ill keep an eye out mate
Yea no exscusises for me its on my road haha might do the slow crawl there in the hunter if I can't sort carbs out in time
No point puting lightened flywheel on if you plan on turboing
Sweet bro use to see this every day at uni always loved the rims
Found them mate http://www.trademe.co.nz/Browse/Listing.aspx?id=666327202 Auction has closed but I'm Shure he will relist he's off the forums here I'm pretty Shure
Oh just had a look mate they not there any more would of been 2 weeks ago there was a set or webers with mani and filters there is just the stromburgs at the moment not Shure if the others sold or I auction ended as never saved to watchlist
There's a set on trade me atm
All u need off a 3tgte is exhaust mani and turbo sump and oil feed /return and its all bolt on factory ecu will take about 10psi on standard injectors don't push it pas there without dropping compression or your in for big shit as I found with my supercharged 2tgeu on 15psi
