smokin'joe replied to Roman's topic in Tech Talk
could be very wrong, but...…. when I was doing dual air gauges for jap truck compliance, there was an outfit in CHCH that was supplying Jap metric to BSP/NPT for the conversion, Transpecs ???????? am away in boonies ATM, but try your local brakes company.. i'd be surprises if BNT don't have access to them. -
what brand would you prefer !!! a fella i know is getting them in, and i guess others will be too, unless they are not in fact Chinese, and are made in a by his clever brother in UK?
smokin'joe replied to TimShadboltfan27's topic in South Island Region
i'm calling your bluff , Mr Ritchie. you want to savour the flavour of the DoBro snags at Riversdale butchery. BTW, when do you head back to the pig island ?- 1,055 replies
- meat raffle
- meat raffle
(and 1 more)
Tagged with:
i wanted a price for 350mm long, 180lb/in coilover springs and Bilstein inserts. Chris was adamant i needed to send the entire unit up for him to measure and fit, then charge a 're-valvling fee for an off the shelf part. have also heard some of his rebuild parts are not the real deal, but merely a knock-off
@idealneil........ Techneil in CHCH. does real rebuilds up to WRC spec. after the limited contact with Chris at Suspensiontech i wouldn't waste my time with thim
good in theory, but use heavy grease on drill bit to avoid ingress of swarf, weld a threaded insert on there so you can change the oil grade if to soft/ stiff
smokin'joe replied to yoeddynz's topic in Project Discussion
good work on the bonnet, mine was in better nick, but was told it would be $1500 to get real good again!!, maybe i didn't need the spendy one from Aussie ?? radiator looks like CR39 Liteace van (can measure one here for you) , but the EA82 Subaru Leone had a similar one from memory -
@cletus , what's your take on the legality of a non-welded twin master set-up like this : as i am going with Wilwood 4-pots on front of Levin, i am thinking a bias system will be easier to tune than mucking around with M/Cylinder sizings . Fanx
might as well be. i'm not fit for public display
funny you should mention my common mistake !! went to weld up the crate on the scrub truck, and realised i done it again. just as well the bottle was only 1/4 full, and the refill is free on the BOC Home D plan
you pissing off to live back in the pig-island ??, or just a seasonal excursion ??- 1,055 replies
- meat raffle
- meat raffle
(and 1 more)
Tagged with:
More shit I don't need - Car Pickup in Dunedin
smokin'joe replied to gettinroundtuit's topic in South Island Region
when are you looking to by and what is it ? you may be able to pick me up on way through, or borrow my trailer if it fits............ providing it is when i am in the Catlins -
should be easy enough to re-kit them, as they will be a generic piston/seal i'd be more concerned about the wheel bearings, as the Trojan ones on my trailer were MK2? Zepher and were over $400 per hub to replace, if they were obtainable
cheers, found that last nite, and i guess if everything is mounted as close to original bumper line, it should be ok. some of the ones i have seen, leave a lot to be desired
@cletus does a winch bar need cert ? did search on here, but no result. fanx
would repower to suit. can't be any more gutless than a HFZ !
does that make it an LFD ?
sorry Barry, but to correct you. RB's may have been in existance in '85, but RFB wasn't even a bunch of sperm in dad's bags in 85
maybe RFB is why it has been made pre-98?
1998 ain't Old or cool
good score, Luke this may be the needed motivation to do something with mine!! i reckon i still have A>K50 box in shed as well as bumpers if you are wanting
i'm sure it was Jeep that the stock car guys referenced as OEM for stock-car use... not that i own a stock-car -
Jeeps are performance, arn't they ?? -
brand new 86 rotors from brake shop here in town $75 brand new willwoods from idiot that was broke $200 CAD CNC brackets from mate in Dunedin $100 all in the last 12 months, not fitted to car, yet. late hubs made me $25, once i sold bare struts to an 86 owner -
the recipe i am using, well proven in KE and KP willwood superlite 4 pot AE86/Late KE70 hubs and 230mm AE86 discs CAD machined brackets can still run a 13" wheel, only variable is bolt pattern for donor struts owe me less than $400 and only hubs are s/h
