Everything posted by datlow
piazzanoob's 1964 ford Galaxie 500 seeedaan
datlow replied to piazzanoob's topic in Project Discussion
We have 25 Ish kg magnets at work pulling them apart is a mission if that’s a legit 112kg you’d probably dent the shit out of the hubcap trying to get it off chuck it in a sock etc so you can slide it off without damaging/denting -
Correct no need to disconnect running something of one battery will pull that battery’s voltage down and probably affect the whole thing always Been taught/told to prove test prove your meter Check it against your trucks (fairly) known voltage to ensure its accuracy also check what the charger is outputting as that could be stuffing it all up
Eastcapescapade 2021 November 12th, 13th, 14th
datlow replied to johnnyfive's topic in Upper North Island Region
Might start this weekend….. -
Can buy foam “baffling” comes in those square fuel cells etc (google fuel tank foam) https://nzkw.com/shop/brand-new-nzkw-yellow-buffle-fuel-foam/ intank setup is just flexi hose to a pipe so should be able to find one close an fine tune the length easily? or go fancy aftermarket universal ones https://www.holley.com/products/fuel_systems/fuel_pumps_regulators_and_filters/fuel_pumps/in-tank_retrofit_fuel_module/
registering my intent anyone got a spare bed for each night? -
EpochNZ's Teenage Wet Dream Sierra Estate - Discuss!
datlow replied to EpochNZ's topic in Project Discussion
wanting manual? Try and find a complete one of these? https://www.trademe.co.nz/a/motors/car-parts-accessories/ford/engines/listing/3232027429 -
Ling/ Lol we buy them from our head office for 86 cents each…. them other company’s are making some coin
Electrical wholesalers should do them, I did have a bunch at work but sent them back sorry prob drop shipped but cheeap (also the wholesalers prob get them from these guys) edit: looks like those Other places are pack of 10 so prob cheaper/easier if NZ https://nz.rs-online.com/web/p/temperature-sensitive-labels/0555409/
yeah nzta virm and roadcode arent all 100% the same kind of fair i guess as you still need to get your car home if the lights fail etc but only thing i can see on virm is
Pretty sure it’s still not a wof requirement ?hence all the cars with obstructed plates and vinyl “plates” still getting wofs /when I put my scooter back through I didn’t even have the bike nor plate there- found the one welly place that was laxed enough but….
Also gotta get it approved before going to vtnz, otherwise they will just issue it with new white plates ^email them with pictures of both plates (best if still attached to the car with old bolts etc) and proof that it was previously regod- either car jam or in my case I had the original certificate thing below Thank you for your email regarding the reissue of number plates. There are a few things that need to be met before we can consider your application to reissue the number plates to your vehicle 1. The number plates must have been previously assigned to the vehicle 2. The number plates must be in mint condition 3. The number plates cannot have been made into personalised plates. 4. The number plates requested for reissue must have not been superseded by a new number plate i.e. the vehicle must not have been registered with new plates or have undergone a plate change.
They asked me for pictures of both plates to reuse them /could get one remade (not legitimate) if you want to run them and send some fuzzy pics in and hope they don’t spot it
@RUNAMUCK My go to for lots of things is comac, zero human interaction and stuff just turns up on the courier etc https://www.comac.co.nz/rubber-grommets
it would be made to do 12+ volts output to keep battery charged etc on a average day, same as a alternator does at idle then on a sunny day it’ll be putting out 15+ volts, like a alternator would do at high revs- they have a regulator that stops that so you need one for the solar panel look for a solar battery maintainer should all be built in, or a seperate regulator
And make sure it’s regulated somehow
https://www.pdl.co.nz/products/detail?CatNo=PDL56SW320FRLE&itemno=PDL56SW320FRLEGY&tab-document-1=0# Wiring instructions https://download.schneider-electric.com/files?p_Doc_Ref=659200&p_File_Ext=.pdf There’s smaller ones-plenty on Ali etc surely some Chinese lathe shop would stock spares?
Just tow the caravan to gizzy -
Hugs, not drugs -
Got mildly enthused today and pulled the remnants of the carpet out simple green, scrub brush, water blast and vacuum long dead mouse
That’s a hell of a vacuum job you did there, almost looks brand new!
Those numbers don’t ad up? or was the 236.78 just for alignment?
Loooong whistle big boy zorst and dose pipe plz
Should do, or try global welding supply’s etc
