datlow
Everything posted by datlow
  1. yeah it doesnt actually work/ i dont have a key for it new lock above also doesnt have a key but its app based which is handy for night walks and child as the only thing he doesnt loose is his phone
  2. Random restorations of stuff you didn’t make cause you weren’t around 110+yrs ago dirty hands, clean knobs before, @V8Pete fav landlord special
  3. Inherited some cast alloy bench seat ends from late FIL (apparently he worked at the foundry in his youth somewhere in the Naki) had some scraps of MAC so figured I’d go with a “rustic” look now to get them powder coated and seal the wood
  4. Your welcome to plow my lawn anytime vg
  5. Na it’s all of the weight and none of the power will sort bike licence on my 400 and get something bigger maybe
  6. Lols look what I found In the shed…… when’s the next free listing weekend? Child is now basically as tall as me (still can’t hold a torch steady)
  7. Guessing you’ve seen this? https://www.instagram.com/p/C9eWlPpiiMH/?igsh=MXE0dWExdThybDAwdA==
  8. Anderson plug would work maybe a 4 way small for speakers 2 way bigger one for sub https://www.jaycar.co.nz/4-way-shell-for-15a-anderson-connector-with-latch/p/PT4436 (Can’t actually see what this one plugs into unless it’s both M&F) https://www.jaycar.co.nz/anderson-sb50-power-connector-50a-6-gauge-contacts/p/PT4420 They have panel mounts for them too
  9. That’s why it also has the vin number on the tag
  10. * cm009 for a long option https://www.autobend.co.nz/exhaust-products/hardware/mounts
  11. @Nominal probably already found them but for future reference assume these are them (sans picture) https://webstore.autobend.co.nz/product/fiat-124-125-132-short-hooks-10028.htmx
  12. Here https://www.nzta.govt.nz/vehicles/how-the-motor-vehicle-register-affects-you/who-can-access-register-information/ but also I wanna do a plate check/car jam before buying so mostly idiots idioting
  13. Still can find it…. can opt out of being searchable from memory
  14. Bulkhead would probably be the most reliable and should be Able to get in brass if heats a issue But these would look tidy if you can't hide it (might not like the heat either?) https://sapsltd.nz/uniseal/
  15. Logic, thought this was OS..... Call the cats BARRA and PLUS T
  16. Robots go here....
  17. And don't dip your magnesium Ferrari wheels.....
  18. was the old one stuffed? could likely get all parts for it as keihin still make carbs etc
  19. no originals likely a keihin? carb, that mikuni would be a reliable upgrade though (if the china carb doesn't work out)
  20. if the china carb doesn't work out, they have a few options and adaptors to use og airbox https://mikunioz.com/shop/1-honda-xr-250-mikuni-tm33-8012-pumper-carb-kit/?v=13b249c5dfa9
  21. thought they had pics, but its all upper sills not the flappy bits, https://vehicleinspection.nzta.govt.nz/virms/entry-certification/reference-materials/non-structural-cosmetic-damage/sillsrocker-panels-minor-damage does mention this though 'A vehicle is not required to be referred to a specialist repair certifier if it has minor underbody impact damage as a result of ‘grounding’ the vehicle or some scraping of the sill seams." https://vehicleinspection.nzta.govt.nz/virms/entry-certification/i-and-c/vehicle-structure/threshold-for-requiring-repair-certification
  22. 190mm tyre would look gooood on it...
  23. Find vw equivalent P/N!? Rock auto/fcp/pelicon maybe
  24. I'm sure I've been feed a sharn about maybe that ^, meaning it disengages the speedo so can be sold as low k rav after being towed around the island for several years
