datlow
Everything posted by datlow
  1. Got enthused this arvo and did a bit more matty b the tank as it’s bare steel (can’t decide what/how to paint it properly ) fitted chain and a sr244 golden boy to the rear as they’d run out of matching 700 that’s on the front big boy tyres are a ball ache to change Went to roll it of the bench only to discover that the centre stand locks up on the knobs ditched that, got it on the ground and it now has the mean gangster lean on the side stand have found a longer xl125 one that I’ll mod and fit
  2. M33x2 NZ$ 0.55 | M12/14/16/20/22-M60 Metric Male Aluminum Oil Sight Glass Window Use For Air Compressor Lathe https://s.click.aliexpress.com/e/elK1fNfK for the other two that’s pretty close to 1/2 and 3/4 bsp? Bung them in with some sealant?
  3. 3ph = easy change any two of the three phases and it’ll change direction, so can be a switch anywhere along the power lead 1ph= only one phase so you need to change around 1/2? Of the windings in the motor some will have all the windings wires run up in to a distribution block so can be tapped into with a rotary switch some will have them joined together down in the windings so can’t be altered and it’s fixed direction
  4. Turns out it kinda fits the back have installed og longer shocks back in then went to install brakes but the drum bar? Didn’t clear the Tyre so stole one of the dirt bike that’s longer and welded a kink in it bought a shinko 700 4.60-17, juuuuust fits the front (should buy on for the back too) what it kinda looks like atm (Didn’t take one with longer rear shocks) 3 weeks till Ueraweras.....
  5. Wanna borrow a bike /some assembly required
  6. Booked a ferry yet? or install some of these and just full send?
  7. Looking wheelie good!
  8. One adventure Tyre fitted, so I’m pretty much ready right......
  9. seems to on the neighbours Maserati, altho i recall maybe petev8 saying you can pull a fuse (on his aston) and its always loud mode also hes a street over and i cant hear it from my house so not thaat loud
  10. Is that the rig you use at the hospital too??
  11. gonna buy some rim tape today.. safety first!
  12. Shit yeah not long to go now do we need to transfer some moneys over for incidentals/ meat flavoured snacks? Can’t remember if it was on the form and or if I’ve paid
  13. BBC I hope /why no ureweras Tortron?
  14. /hairy beard rides? You must be exhausted
  15. Been lazy, stripped the Cm125t had parts vapour blasted Fuel tank suprisingly only had 2 dents under several layers of paint and full coat of bog have it as work to try and remove dents then hopefully get it powder coated had forks and front rim powdercoated, bought a complete ali rear wheel (wider rim and bigger spokes), bought some spokes for the front but they may be a tad too long reckon they look nice tho now to mock up and find some tyres and tubes to fit got a s/h cheapy 120/90-17 but it’s too wide
  16. Hope he doesn’t get stage fright with 30 other guys watching....
  17. My van has as standard a weird angled filter, luckily the engineers actually thought it through and built in a little oil ramp/drain thing
  18. Yip big one with hydraulic wrench and 30+ bolts takes about 3-4 hours with two people other one is 12 bolts (cheat and use a rattle gun for most of it) and then swing on a 800Nm wrench after
  19. We use same style thing at work one for the main shaft that’s about 500mm and another maybe 150mm diameter for the brake disk they handle the 2000kw+ no worries doing them ups a right cunt nugget tho
  20. Probably not, but I’m Coming up to Tauranga next month in a van weekend of the 19 oct
  21. Yeah the insides of the solenoid will be pretty shitty and prone to doing it again/ could go the other way and not engage properly too either pull apart and sand contacts smooth (prob a cheap cast plastic unit tho) so yeah buy a new one
  22. Ah excellent my cm125 is 6v and piss poor headlight etc, keen for 12v so I can use a spare led speedo etc too guess I should get it back together and running and figure out all this black magic
  23. was it 12v before the electrical mods?
  24. Ah the ol buy another bike that runs trick! at my current rate that’ll be me
