Everything posted by AllTorque
I'd be happy to be incorrect on this one, but I cant find anything in the virm that says there are different requirements for trucks and cars apart from the different requirements for dual wheel vehicles My interpretation is a vehicle either has individual mudguards or a body panel mudguard. Like most of the virm it is unclear. Any time I have called nzta for help they tell me to use my judgment.
Here is my understanding of current WOF requirements for mudguards. The cover down to the centre line rule is for trucks or flat decks that have a seperate ‘individual’ mudguard. If a car has the body panel as the mudguard it does not need to go down as far as the centre line. https://vehicleinspection.nzta.govt.nz/virms/in-service-wof-and-cof/general/tyres,-wheels-and-hubs/mudguards
Sublet, so another company has done the alignment. Maybe they are charging time for the apprentice to drive the car to the alignment place and check his Facebook while they do the alignment and drive the car back to work?
Oh,wait, just saw the bottom number. $236 for an alignment and wheel balance. something is not right. Should be half that
Looks to me they have removed the wheel from the car, removed the tyre from the wheel, repaired the wheel, painted the wheel, fit the tyre, balanced the tyre.
Probably not, but it’s easy to spray some cleaner on it. Or try starting it with the AFM unplugged. Some cars will start without them. Another thought, crank sensor?
Is your air flow meter covered in K&N oil?
Yes it is ok to seal over the crack. As long as it doesn’t effect the pattern.
Shit, that looks good. Better not get it dirty.
Cool. The booster has a ‘silencer’ or ‘filter’ that is foam around input rod. Chances are when the new pads were put in or the brakes bled and the pedal was pushed all the way down the foam has fallen apart. If the brakes are working as they should,then the booster is sad. If you get a hard pedal or poor stopping performance, the booster is dead. Either way, I would recommend replacing the booster.
- 13 replies
Sounds like a sad booster to me.
AllTorque replied to KKtrips's topic in Lower North Island Region
I wasn’t until you reminded me. -
Out, soz. -
Usually you can tell if engine oil or coolant is leaking, because it’s wet and not an invisible gas.
They may not even need a resistor.
I think you would use the one in the left or the three on the right , but not all. Factory fitted steering wheel controls (in Toyota at least) Have one output. Each button has a different resistor, so the stereo sees a different voltage for each button and knows what to do.
That reminds me of the time I was doing a WOF on a Land Rover. Did a 30kph hard brake test, pedal went to the floor and Landy kept rolling, handbrake stopped it eventually. A hard brake line burst open length ways.
See you monkeys tonight -
Wow, just like old times. -
Those guys will make you one with a receiver if that’s what you want.
@Bling try these guys to compare a local price https://www.towbar.co.nz
Sounds like the starter brushes are worn out. Hitting the starter with a hammer shocks it into starting, but you only get a few hits before the brushes are completely done. You can replace just the brushes.
Knock on wood quick or you’ll jinx yourself
