Everything posted by AllTorque
AllTorque replied to KKtrips's topic in Lower North Island Region
If he’s in, then I’m in. -
Just red bulbs may not output enough red. You may need to colour the lenses too.
Do you mean like a round headlight? Probably could, but why would you? You will need to have a reflector as well.
You can’t just cut out the rust and leave a hole. Replace the structure with metal.
The 50mm rule is only for places in the shaded area of figure 3-1-2 https://vehicleinspection.nzta.govt.nz/virms/in-service-wof-and-cof/general/vehicle-structure/structure-incl2.-frontal-impact#figure312 Doors must have no rust within 150mm of the hinges or catches.
Don’t need to flash for a wof
Cone type LSD is weak. Can use tubes and axles in a 9”
What’s the theory behind using an expansion chamber?
- 417 replies
Buy me a beer first -
Nice. You are very organised this month, Niki. -
IMHO repair is ok as long as water can’t get in and the wrong colour light can’t come out (like white out a tail light.
What was the coolant like? Any chance different coolants were mixed?
Have you considered having all your projects in one thread?
Oh man, that sucks. At least you got the wiring sorted. Do you have any pics of the trike?
@Roman May have some ideas. How are you cam and crank signals at the ecu? Are you getting cam position from both banks?
Congrats on reaching this milestone. Looking so good. You look pretty stoked at the end of the vid.
Put your chassis number in here to find the genuine part number and go from there. http://www.toyodiy.com/parts/q.html
I replaced my alternator with an aftermarket that was cheaper than my genuine price.
That’s the closest I can find. Hope it helps.
Wof rules for mirrors. pre 2000 you must have interior OR right mirror. post 2000 you must have both. If you have tints you need both side mirrors. https://vehicleinspection.nzta.govt.nz/virms/in-service-wof-and-cof/general/vision/rear-view-mirrors https://vehicleinspection.nzta.govt.nz/virms/in-service-wof-and-cof/general/vision/glazing see tables and images
I just checked the repair manual. It says to remove the left exhaust manifold first. Good luck.
Looks like standard aftermarket tow bar fitment, but you are in the money, you would want some crush tubes. They are probably still in the car it cane off, but easy enough to cut some pipe.
Good advice above. There is a filter. It should be a steel mesh type that can be cleaned. Not usually changed for a Toyota Trans Service, but we don’t see a lot of them over 500k. It probably is worth taking the pan off and giving it a clean up. Make sure you use the correct fluid. Recently there has been a shortage of Toyota Genuine WS atf and we have been told to use Dexron VI.
