GARDRB Posted April 8 Share Posted April 8 It's looking like I'm gonna need a 3/4" Clutch master to work with my hydraulic throwout bearing. It's going into my 1uz Ce71/Ke70 Wagon. The factory CE71 cylinder is 5/8" and roughly 85mm long with a vertical bolt pattern. I've found a Tilton cylinder that appears to be the best option so far, but if anyone has any ideas for something that's OEM and more OEM-priced I'm all ears. The factory one is very cosy with my driver's side head, so I can't go any longer realistically. I'm not keen to go to reverse swing. This is the Tilton option. https://www.cardwells.co.nz/product/tilton-master-cylinder-76-series/ Quote Link to comment Share on other sites More sharing options...
Roman Posted April 8 Share Posted April 8 If you can only find one with right geometry but too small a bore, you can get them bored out and put bigger guts in Bit more of a pain than finding an off the shelf option though. Quote Link to comment Share on other sites More sharing options...
smokin'joe Posted April 8 Share Posted April 8 liteace springs to mind, as needed short unit to avoid manifold in a KP60 . may only be 5/8, though Quote Link to comment Share on other sites More sharing options...
NickJ Posted April 9 Share Posted April 9 Trailer brake master cylinder? Quote Link to comment Share on other sites More sharing options...
GARDRB Posted April 9 Author Share Posted April 9 11 hours ago, NickJ said: Trailer brake master cylinder? Funny you should say that. I just measured one at the parts place. Sadly too long. At the moment Mr Tilton is in the lead, followed closely by Mr RomanDave 1 Quote Link to comment Share on other sites More sharing options...
JR Posted April 13 Share Posted April 13 I had a similar issue recently, I'm not sure where you are but these guys have quite a good website with pictures of all of their master cylinder. It helped me out. https://www.butlerautomart.co.nz/Our-Range/Clutch-transmission/Clutch-master-cylinders/Index.aspx This is the one I bought, actually looks similar to the one in your link. https://www.butlerautomart.co.nz/Our-Range/Clutch-transmission/Clutch-master-cylinders/Product-Specification-32987886.aspx 1 Quote Link to comment Share on other sites More sharing options...
Bearded Baldy Posted Wednesday at 08:01 Share Posted Wednesday at 08:01 Xa to xe series falcon might work, very similar to trailer ones but cannot remember which is shorter. Quote Link to comment Share on other sites More sharing options...
