GARDRB Posted April 8 Share Posted April 8 It's looking like I'm gonna need a 3/4" Clutch master to work with my hydraulic throwout bearing. It's going into my 1uz Ce71/Ke70 Wagon. The factory CE71 cylinder is 5/8" and roughly 85mm long with a vertical bolt pattern. I've found a Tilton cylinder that appears to be the best option so far, but if anyone has any ideas for something that's OEM and more OEM-priced I'm all ears. The factory one is very cosy with my driver's side head, so I can't go any longer realistically. I'm not keen to go to reverse swing. This is the Tilton option. https://www.cardwells.co.nz/product/tilton-master-cylinder-76-series/ Quote Link to comment Share on other sites More sharing options...
Roman Posted April 8 Share Posted April 8 If you can only find one with right geometry but too small a bore, you can get them bored out and put bigger guts in Bit more of a pain than finding an off the shelf option though. Quote Link to comment Share on other sites More sharing options...
smokin'joe Posted April 8 Share Posted April 8 liteace springs to mind, as needed short unit to avoid manifold in a KP60 . may only be 5/8, though Quote Link to comment Share on other sites More sharing options...
NickJ Posted April 9 Share Posted April 9 Trailer brake master cylinder? Quote Link to comment Share on other sites More sharing options...
GARDRB Posted April 9 Author Share Posted April 9 11 hours ago, NickJ said: Trailer brake master cylinder? Funny you should say that. I just measured one at the parts place. Sadly too long. At the moment Mr Tilton is in the lead, followed closely by Mr RomanDave 1 Quote Link to comment Share on other sites More sharing options...
JR Posted April 13 Share Posted April 13 I had a similar issue recently, I'm not sure where you are but these guys have quite a good website with pictures of all of their master cylinder. It helped me out. https://www.butlerautomart.co.nz/Our-Range/Clutch-transmission/Clutch-master-cylinders/Index.aspx This is the one I bought, actually looks similar to the one in your link. https://www.butlerautomart.co.nz/Our-Range/Clutch-transmission/Clutch-master-cylinders/Product-Specification-32987886.aspx 1 Quote Link to comment Share on other sites More sharing options...
Bearded Baldy Posted 19 hours ago Share Posted 19 hours ago Xa to xe series falcon might work, very similar to trailer ones but cannot remember which is shorter. Quote Link to comment Share on other sites More sharing options...
