Stu Posted September 21, 2023 Share Posted September 21, 2023 Full send on the abuse here... Quote Link to comment Share on other sites More sharing options...
Roman Posted September 21, 2023 Share Posted September 21, 2023 Shameless EP starlet fanboy reporting in for duty. Have you considered a 2ZZ 1NZ? 1 2 Quote Link to comment Share on other sites More sharing options...
Stu Posted September 21, 2023 Author Share Posted September 21, 2023 My dream build is a 1e based bottom end with a 4e head. All the rpm. 1 2 Quote Link to comment Share on other sites More sharing options...
xsspeed Posted September 21, 2023 Share Posted September 21, 2023 Waiting for @Truenotchs updates ^ 1 1 Quote Link to comment Share on other sites More sharing options...
Truenotch Posted September 21, 2023 Share Posted September 21, 2023 Get that 74x64mm bore and stroke up ya! 1 1 Quote Link to comment Share on other sites More sharing options...
Stu Posted September 21, 2023 Author Share Posted September 21, 2023 I've got all the bits sitting there l, just haven't had time. Too many other projects haha 1 Quote Link to comment Share on other sites More sharing options...
kpr Posted September 22, 2023 Share Posted September 22, 2023 5e block with all the rod ratio i hope. 2 1 Quote Link to comment Share on other sites More sharing options...
Truenotch Posted September 22, 2023 Share Posted September 22, 2023 1 hour ago, kpr said: 5e block with all the rod ratio i hope. That'd be the dream, but 5e bottom ends are 42mm and the 1e crank is 40mm, so 1.9:1 will have to do. 1 Quote Link to comment Share on other sites More sharing options...
xsspeed Posted September 22, 2023 Share Posted September 22, 2023 guess thats only 4 spec'd rods away for 2.04 RR Quote Link to comment Share on other sites More sharing options...
Popular Post Roman Posted September 22, 2023 Popular Post Share Posted September 22, 2023 The current state of oldschool.co.nz Toyota meme engines. 5 1 4 Quote Link to comment Share on other sites More sharing options...
xsspeed Posted September 22, 2023 Share Posted September 22, 2023 Almost enough to get an ee/ep again 3 Quote Link to comment Share on other sites More sharing options...
Roman Posted September 22, 2023 Share Posted September 22, 2023 6 hours ago, Truenotch said: That'd be the dream, but 5e bottom ends are 42mm and the 1e crank is 40mm, so 1.9:1 will have to do. 1.9 rod ratio, and at 10,000rpm its mean piston speed is same as a 1NZ at 7500. So keen to see how this goes haha. 1 Quote Link to comment Share on other sites More sharing options...
xsspeed Posted September 22, 2023 Share Posted September 22, 2023 And only 74mm bore so pistons should be light 2 Quote Link to comment Share on other sites More sharing options...
Roman Posted September 22, 2023 Share Posted September 22, 2023 Hey @Stu thanks for starting the 1E chat thread. I can come help when you're ready to 1E either the white starlet, blue starlet, or AE86. 1 1 2 Quote Link to comment Share on other sites More sharing options...
Stu Posted September 22, 2023 Author Share Posted September 22, 2023 Lets put it in the 86 just to mess with people 2 1 Quote Link to comment Share on other sites More sharing options...
xsspeed Posted September 22, 2023 Share Posted September 22, 2023 I seem to remember someone did a rwd e motor in a kp years back on here Quote Link to comment Share on other sites More sharing options...
xsspeed Posted September 22, 2023 Share Posted September 22, 2023 But you should obviously convert 86 to fwd, should be able to get a c60/160 attached to engine via some bellhousing lego 4 Quote Link to comment Share on other sites More sharing options...
Stu Posted September 24, 2023 Author Share Posted September 24, 2023 On 23/09/2023 at 10:29, xsspeed said: I seem to remember someone did a rwd e motor in a kp years back on here Yeah thats Shane's KP. It has a 2J in it now. 1 Quote Link to comment Share on other sites More sharing options...
Roman Posted September 26, 2023 Share Posted September 26, 2023 Shanes car was absolutely hectic with the turbo 5E setup. Was 500something horsepower I think? But a massive on/off switch. Since he's put the 2JZ in, I'm pretty sure the 5E setup is all just sitting in his shed... waiting for a good home... Would be awesome in a GT86 1 Quote Link to comment Share on other sites More sharing options...
