Completely unrelated to any important task at hand, but I've found a box of calipers that "we" gave up on a few years ago, and started working on them again.
The fronts were already reassembled, rears have a painful circlip around the piston adjuster mechanism.
They're down the back of the bore and really difficult to get at, so I had to make some ultra long circlip pliers.
I don't think this ranks in the top-50 on the list of sketchiest things I've done. It did however get the job done, so now I have some rebuilt rear and front calipers to go on my car. I'm hoping this will help with my non-existant handbrake before the next motorkhana in mid October. Also my car is probably far overdue for new brake fluid and I can now kill 2 birds with 1 stone.
  • Replies 70
Generally calipers with integral handbrake don't really have the mechanical advantage to supply even 1/2 of what you might need to execute a decent handbrake turn on a sealed surface, so I wouldn't get you hopes up..
but getting the mechanism working properly and callipers rebuilt is still a great idea to prevent a whole bunch of possible problems..
My hopes were up :(
Nah I was pretty convinced that it wouldn't help my handbrake, but I know my fluid is bad and I'm sure my adjusters are unhappy, so this is a good thing. I'll probably try get new discs all around and new pads too.
Actually thinking back I believe at the last wof I can remember that was at a place with a brake machine, my rear balance was out of wack anyway... oops
My mx5 is not 6lug nor does does it have a big brake kit, so the arrival of GMC sierra/Chevy avalanche/Cadillac Escalade front rotors for the rear of my mx5 was a bit of a shock. Rockauto was good about the refund and I guess I now own some shiny wall ornaments.
The fronts and front pads arrived just fine, but rear pads were gifts from a friend but are also incorrect (nb). I want a refund on those too...
Anyway NZbrakeco sorted out some rear rotors overnight and BNT had some nice pads for the rear so now the brakes are all pretty much done. Just need to mess with the handbrake adjustment points and check everything is okay (cable isn't stretching or frayed etc).
And yeah drilled/slotted aren't necessary for me nor are they as "good" as plane Jane vented rotors, but I think they look cool and they were on special, so cost about the same as any other coated vented rotors.
Edit to point out the crustiness of my old rears, and the reason I wanted to replace them:
Okay so the handbrake is still NFG but the brakes themselves are awesome. It's probably just having fresh fluid and non glazed pads but the brakes feel far more linear to lockup, whereas before they didn't do much until the fronts just completely locked up.
(I didn't hit that cone, somehow)
I did a sccnz motorkhana yesterday (Sunday), placing 5th overall which I'm stoked about! I think the bigger cars struggled on some of the tight courses and I'm sure it would be a different story in an autocross. My dad also drove my car earning a very respectable 12th place in what might have been his very first time trying to drive a car with more than 20% throttle!
Someone also took a video of my slower run of the fourth course:
https://drive.google.com/file/d/1aCg9DYelcsQd_GZSELs4I_Cb2tV9oiOn/view?usp=drivesdk
Still need $$ for further car improvements. Up "next" are new equal length headers and probably replace the muffler as I am now pretty sure the combination of my crap unequal-length headers and a cheap muffler are causing the last of the tinnyness in the exhaust note.
Then I'll need to replace my suspension, the car still behaves very soft even with the dampers set as firm as they will go.
Photo from @mooffy_photo (@mooffy_photov2 on insta)
  • 5 months later...
Another few months of nothing and then I decide to sign up for another sccnz motorkhana. At this point it is 10am saturday, and the motorkhana is 10am sunday. Last time I checked, my TPS is falling off, throttle #4 has a vacuum leak from being yanked about when the tps was knocked, and there is maybe a slight misfire. Instead of even opening the engine bay, I decide the exhaust needs more work and I have a muffler just lying about SOOO a plan is formulated...
I'm also critically out of stainless filler and argon, but that won't stop me
430235281_766772898396249_4499845342149501684_n.jpg.8d226fb2ea7c5b282a3f50be8d596c37.jpg
Contemplating new muffler position, was tempted to have it riight out the bumper but I don't hate myself that much.
431312278_1175340283849385_3809176817696220846_n.jpg.eab8b0ccc58bf8bc6d208c890e2afca3.jpg
Instead, we tuck the muffler right up underneath the car and do a downturned exhaust tip. At this point I was chopping up the old muffler to save argon. Here is where the downturn tip came from:
431303887_840209647937279_5096651226401803916_n.thumb.jpg.9f5b6756fe208001bb1829308e3d1b8c.jpg
After procrastinating a fair amount, I get the muffler all tacked and have completely exhausted my argon bottle. Nice, its about 3pm and I'm making dinner for some friends before a comedy show. Make a lasagne then quick trip to bunnings at 5.30 for an argon swap, comedy show and start "welding" again at about 11.30pm.
432913002_378530511676758_945419050956738878_n.thumb.jpg.67dd82f4e4d6b4c393b81bbb271f4fa9.jpg
Do I need more gas coverage? Sure. Are my "welds" shit and rushed? You know it. Do they work? To be decided. Midnight:30, job done.
432601598_771483641229503_189736054316945334_n.thumb.jpg.bb9a446b8d185527449938dbe49a2bd0.jpg
432854657_1356526831718113_3450414275877576222_n.thumb.jpg.691785679169df9e783a04a058a83b1a.jpg
Car lost some rasp, gained a LOT of bass. Right at 90Hz at motorway speed, heaps of it. So much bass I was getting a headache, and that was not fun.
I figured its about time to actually make the car quiet, so I make a (suss) slip in silencer after the motorkhana. It had to be short and on an angle to be able to get up the downturn exhaust tip, but it does the job. Bass is gone, rasp is gone, car sounds pretty reasonable for once!
432846376_757560119668236_1647564651189100215_n.thumb.jpg.46bfa871be6fdf220de322f82d1c85fb.jpg
Woah 2 updates in less than a year? I must've had too much caffeine.
The plan is:
  1. Remove the intake manifold.
  2. Grind down the clutch master where it touches the TPS. Less sketchy than it sounds, its just a mounting tab for the old reservoir. I kept the master wet to cool it while cutting.
  3. Remove the throttles.
  4. Tidy up the mating surface between the intake and throttles.
  5. Drill out the threaded mounting holes for the throttles. The tapped aluminium was always a bit sketch, I never had the confidence to really tighten down the mounting bolts for the throttles.
  6. Grey RTV the mating surface, longer bolts with nylon locknuts on the back.
  7. Re-install the things.
  8. Hoon.
So, intake off:
419166440_1147427946265210_8050368692598830697_n.thumb.jpg.bce2115fc4cf0754e356caafa461e234.jpg
Clutch master cut down:
432536592_384807487643786_1772711975593973596_n.thumb.jpg.05295c77fb580a6a58b82b040caa759a.jpg
I did the things I needed to on the manifold, I also trimmed down the flange a bit to be less intrusive (compare with older photos):
430333613_711227454548561_3075613333942089181_n.thumb.jpg.46c07912214057514635260375643ed2.jpg
Back together:
432699636_945600503804074_7001800879935731111_n.thumb.jpg.4fe82886d1922caba739c51d30c1cb19.jpg
Aaand in the car:
432847790_1142718496761706_4591967942193020812_n.thumb.jpg.d22f4703b94d7b3c1614e7536400626d.jpg
Results:
Started first pop, was running like shit and my exhaust spat out more fuel than the last 15 seconds of a prepaid BP pump (not hard).
Turns out you need your MAP hose connected (seen by my washer bottle/chassis tag in the previous photo... lol). I guess the vacuum gave enough fuel for it to run super rich, basically WOT fueling.
On the first drive the car was fine. The cyl4 vac leak was gone as expected and I'd spent more time grinding out the inside of the intake manifold, so some of the weird whistles I used to get seem to have gone.
Datalogs looked expectedly poor. I had some help from a very knowledgeable friend about some oddities in some analog sensor readings and we have determined I should probably both chase my grounds and make sure everything looks fine, and also change back from a hybrid SD/alpha-N tune to pure alpha-N, with a bit of analog smoothing on the TPS signal. This will help resolve the very difficult to tune accel-enrichment values and hopefully result in a better driving experience.
Future:
I think besides all of the constant fixing of past-me's neglectful corner-cutting, I need to really look into longer duration cams. I believe the 230/240 8.5/8.9mm values really aren't enough for the kinda tomfoolery I would like.
As the ZL-VE cylinder head has really never done much more than haul groceries, nobody makes cams for it. Regrinds are in order and I will try to take as much inspiration from the NB VVT engines as I can. Maybe 270/270 9.5/9.5mm which purport to be fine for shim-over-bucket lifters. Realistically, moving to shim-under-bucket will cost more than the cams.
I think my engine will become interference with the cams I'm wanting, mostly because the stock b6 pistons have the valve notches for the wider cam spacing (obtuse valve angle) and the valves being closer to the piston when at rest in the ZL head. Oh well, it'll be fun while it lasts!
Vvt is on the intake side right, what's the exhaust cam like in say the ZL-DE? Is it worth swapping the exhaust cam over?
Guessing the intake cam is specific in the ZL-VE or could you use a cam from the ZL-DE or am I thinkingof the ZM-DE, I was reading about ZL-DE/VE or  heads on A series blocks and thought dual Exhaust cams might be an option?
Yep!
226/233, less lift. Same with the ZM-DE (I've had a friend measure the ZM-DE cams and theyre actual trash).
Also yes, unfortunately. Its the only VVT motor Mazda made with this cylinder spacing so I'm almost certain its the only cam thatll fit.
Thanks for the suggestions though, I wish I could grab some off-the-zebra (RIP you will be missed) cams for this but I think getting regrinds is the only way, given the fancy oiling they had I don't even think brand new cams from a billet would be cost effective.
384510751_354818753608199_7254222229463011059_n.thumb.jpg.e3306da5964e3d088ec3ed4d3f1bb51f.jpg
On these cams, the intake cam has all of the oiling setup for the VVT system so I'm not so certain anything will drop in. The cam journals are all oil fed from the head.
On the exhaust cam, the cams self-lubricate from a single feed on the frontmost cam journal, which is distributed throughout the cam through tiny wee oiling holes on the rest of the journals.
The exhaust cam has more lift and duration than a B6 intake cam I think, so it could maybe end up being a cheap drop-in exhintake cam for NA 1.6 mx5s? To be looked at further, by someone other than myself.
Another point of interest is that the backs of the lobes (in the base circle) taper really narrow, does anyone know if this is an issue with re-profiling cams?
Another SCCNZ motorkhana on Sunday 5th, so of course I decided to do a full re-wire on saturday. Okay not a full re-wire, but I re-pinned everything on the ECU side, replaced the TPS wire and connector with 3 core+shield, and ran new wires for IAT and CLT. This photo was at about midnight on Saturday night, pulling the dash is a REAL pain but boy I'm glad I have a convertible. You can see the old bodged birds nest of wires in the passenger footwell. The motivation for these changes was that every analog sensor seemed to change a few percent based on RPM. So at 0RPM the sensor read "normal", but for example CLT increased 10* linearly with RPM, which is not how engines should behave so is not what we want. The other oddity was that my TPS signal had about 1-2* of noise, and that noise was hitting acceleration enrichment at cruise, resulting in weird rich conditions.
Additionally I moved every single splice on a 5v or sensor ground out of the engine bay/loom and put them all into "bussed" connectors right at the ecu. Basically some cheap fake deutsch 4 or 8 way connectors with one side all bussed together. That way I can add or remove or replace ground or 5v wires if necessary without having to replace open barrel crimps in some awkward position under the dash or in the loom. The twin 4-ways are 5v, and the 8-way is GND. I did this so I could never accidentally plug them in to the wrong one.
Also to solve some space requirements I potted the TPS connector and ran it to a 3-way deutsch connector in the engine bay.
At about 2.30am I got the dash back in, and test fired it. You can see the ECU's new home in the dash, preventing passengers feet from strain testing my crimps. I was fully expecting nothing to work, but weirdly enough the car actually started up fine and ran. Unfortunately I made a mistake somewhere (?) and both CLT and IAT read strange, but they have 5v so I suspect I just swapped which ecu pin I put each to. I went to bed.
The next morning I got the car "properly" running, assembled the rest of the dash and headed off to the motorkhana. I also changed the tune from hybrid SD/alpha-N to pure alpha-N and turned down the acceleration enrichment. It helped a lot. One of the issues I had with the blended system was that my acceleration enrichment curve meant I needed heaps of fuel for large ΔTPS at low load (SD, map-based load), but as load increased and it swapped to alpha-N, the amount of required fuel was less. My understanding is that this is because TPS updates almost instantaneously, but MAP can delay a small amount (in the hundreds of ms) so you use ΔTPS as a stopgap to throw in a bit of extra fuel until the map sensor catches up. Unfortunately if the ΔTPS means you are now using TPS based load, then the required fuel causes a rich condition. More tuning is required, but mostly I do acceleration enrichment by "feel" not what the AFR says. If it feels peppy, it's probably good. I'll post another update soon if I can eventually find any photos of my car from Sunday's motorkhana.
Free, inconsequential update time.
I "acquired" a clone of the irp-style short shifters a while ago, one of a batch that had some issues and was essentially worthless. The issue is it didn't come with the lower ball, so I had to make one. 304SS 15mm ball bearing welded to a cut down M12 bolt, and this problem is solved. The shifter is really nice, its super notchy with the brass bushing (unsure how long it will last) but I do plan on cutting the shifter and welding it in a "Z" shape to bring the shift knob closer to the steering wheel a little bit. Something like the offset shifters you see as an option on quaife(?) gearboxes.
Next free thing was yet another exhaust change. I'm about to move from those trade'n'go argon bottles at bunnings to one of those fancy F3VIPR bottles, so I need to refill gas less, and it costs me significantly less in the long run too. I need to use up the last of the argon so I decided to move my exhaust tip to the other side, mainly as tig practice but also to provide one more bend for the exhaust gasses to travel around. This also let me use more exhaust hangers (not pictured).
Also the towbar is gone :( I decided it was time to say goodbye to my dream of towing boats, car trailers and campervans with the mx5 and decided the 20kg or so was not worth it (lol). Also pictured is the CF bootlid my friend made before selling his car. It still needs a final trim, sand and 2k clear but it looks kind of neat. Not sure if I'll end up sticking with it or going back to the white painted boot but for now it's on there
