44 minutes ago, mjrstar said:
Awesome project wouldn't mind myself..
As far as the trailer build I have a similar designed trailer for my Honda which has been great except it continued to crack the risers for the top rail on the sides from the points from the axle forward to the front.. the issue is these are limiting the bending moment and there is no triangulation.. I ended up shortening the cross bar along the front so the sides dip down to almost triangulate the sides similar to how your back section is and then I added a diagonal in just the first section.
Sorry if my explanation is garbage, but it might save you a repair job after its galv or painted.
I think I know what you mean. I was considering adding in triangulation like this or similar,
Most of the weight in the SXS is probably just in front of the rear tyres.
  • Replies 85
Yep, pretty much, I rewelded mine a couple of times but it continued cracking the steel, has been algood since adding the diagonals. the load on yours won't be front heavy like mine though.
Recently finished this trailer designed for side by side, small tractor, Two quads etc.
Engineer mate suggested doing the bulk of the welding from side to side with minimal welds running front to back, which allows the trailer to flex just a lil bit.
Seems to be working so far.
Looks nice, there is a lot less bending moment with a tandem axle, as the point loading between spring hangers for weight distribution is far more spread.
Yea I went a bit overboard. Probably could have got away with one axle and no brakes. Also took the drawbar steel right back to the centre pivot of the tandem springs. Tows real nice.
  • 6 months later...
SOOooOOoOOOoo I took a week off to finish the trailer, and didn't even touch it, started on the kids mini land cruiser instead, lols. I did take the SXS to nats, which has been its only outing for fucking ages (too many jobs at home to be done). Photographic proof of it being used (thanks to @Thousand Dollar Supercar)
It was good to have a hoon on a flat surface (big thanks to @Thphantum) to try and get used to the handling, 4WD is still a bit strange to me. Didn't roll it, which was excellent.
And seeing as I've hardly used it, I decided to waste more money on it, by buying a second hand set of the correct OEM bead lock 14" rims complete with more aggressive mud spec tyres, as my local track is often muddy as a son of a gun. The other reason for buying these, is so in the future I can go to a bigger tyre to gain a bit of ground clearance. It currently has 27's, the new tyres are 26's, but there's waaaaaaaaaay more options for bigger tyres in a 14". I've found out, nearer the end of the day, I start to have ground clearance issues, as the modern SXS's all run way bigger tyres (I think most come with 33's standard, and some go up to 35's) and they dig huge trenches in the tracks, so going up a few sizes should help with that issue. Can't go too big though, cos I don't have the power/gearing for dat.
And a pic of what my SXS is actually meant to look like, with the rims I've just purchased (wish I still had all the black plastics rather than the fucking rainbow it is now sadface.com)
 Lame update sorry, don't have much to do at work, lolololols.
Regards, VG.
