  • Replies 147
39 minutes ago, RUNAMUCK said:
We need to borrow that jig some time too.
Oh yeah........what are you building a diff for.?
Had it since I had my escort van.lol
Shortening up a bw78 to go under a Val.  Current has a 2.92:1 type 75. I've run a 12.5@107. The 3.45:1 AU rear axle should knock a tenth or two off that
He'l yeah.....hiw.much shorter is the valitank housing
2 minutes ago, RUNAMUCK said:
Tons.
I think it's like 55 inches drum to drum?
Wow that short mate  like 20mm wid er each side than an escort diff.
And holy shit mate 12.5 is a very respectable time
It ain't slow. It's even better that it was done with such a steep rear axle too.  I know another user on this forum who's run quicker on the same ratio.  But they had a tacho, and a proper shifter.
So what are you hoping for 12 flat or high 11s
Faster the better.
Lower diff ratio
Decent shifter
Tacho with shift light
Double pumper.
Car will never be converted to a full drag car. But it'd nice to get a low 12 or better.
*I think you can have a 74/75 carrier machined to take the 4 spider bits out of a 78*
I don't know to be honest.
But from fucking about with diff swaps I'd say,
Can you get a Quaife LSD for the Cortina/Atlas diff?
Is the width close to a Hilux?
What are the chances of finding a 9" that someone has shortened for a Cortina back in the day?
In my experience the cheapest option often ends up more expensive.
Very true Pete..
The easiest option mate would be 25 spline xa.b.c.d.e.f 25 spline lsd diff and put the lad in the Aussie cortina housing..
And I'm still on the hunt for 1
15 minutes ago, Valiant said:
I've got one you gave me years ago.
Do you want it back?
Did I ? Lol.
Is it just the LSD carrier?
On 28/10/2017 at 21:09, bigfoot said:
Mk4 and Mk 5 are pretty much the same anyway
Except that almost nothing is the same.
That would go.straight into karts aussie CortIna housing. Bolt together set up mate.
yeeesssss but. lol
i might want discs and 5 stud.... because im a fucking idiot
Just now, RUNAMUCK said:
Weld.up the corty axle flanges and re drill to five stud.
that could be another problem as there is 1 hole that needs fulling for re drilling and some cert dudes dont like that.......
but.......would they really look.
