Matteybean Posted June 14, 2015 Share Posted June 14, 2015 Hey guys just got a question regarding my 18rgu.. Its a low km engine . I replaced the oil when I got it (I didn't change filter yet as planned on dropping oil again say after a few hundred kms . My oil pressure sensor I think is hooked up . Connected it to the little dome at the arse end of the oil filter with plug to match. Now I haven't driven this on the road yet just had it idling at home . When I turn the engine over the light comes on and turns off after couple seconds as it should . But when I look closely I can see the light flickering it's so dim you would miss it unless I pointed it out. Altho . When I accelerate it comes on bright until the Revs drop back to idle. The oil is exactly the right amount in there. Any ideas or should I be worried ? When I remove the sensor when engine is running the oil light on the dash doesn't come on ? Have I connected it in wrong or is some gunk blocked somewhere ? I changed sumps engine is clean as inside and oil pick up filter is crystal clean no gunk on sump etc etc Now that I'm writing this I've prob answered my own question .. engine hasnt been started in 20 years but always turned over manually meaning that oil filter is prob from the 80s... could that cause the light to come on ? Any light on this would be good cheers. Quote Link to comment Share on other sites More sharing options...
downtrail Posted June 14, 2015 Share Posted June 14, 2015 Throw a pressure gauge in and find out. Should see 10psi for every 1000rpm if its healthy 1 Quote Link to comment Share on other sites More sharing options...
Matteybean Posted June 14, 2015 Author Share Posted June 14, 2015 Yup ill have to buy one n replace that filter with a new one n go from there . Unless anyone in south auckland area has 1 I could borrow for a couple nights Quote Link to comment Share on other sites More sharing options...
Seedy Al Posted June 14, 2015 Share Posted June 14, 2015 does it look like the on one the left or the one on the right of this pic? (roughly) 1 Quote Link to comment Share on other sites More sharing options...
Matteybean Posted June 14, 2015 Author Share Posted June 14, 2015 Def one on left . The connector is a small circle that the plug sit's over its right below oil filter Quote Link to comment Share on other sites More sharing options...
Mof Posted June 14, 2015 Share Posted June 14, 2015 So you can see by the descriptions in the picture what they are right? Quote Link to comment Share on other sites More sharing options...
Seedy Al Posted June 14, 2015 Share Posted June 14, 2015 ok, that explains everything I think So your saying your oil light is flickering. That's because the sensor on the engine is designed for an Oil pressure gauge, which uses a liner style signal, instead of the one on the right, which just measures if there is any pressure, and makes the light go out. Replace the sender unit that is currently on the motor with the one off your original motor and you will be fine. 2 Quote Link to comment Share on other sites More sharing options...
Matteybean Posted June 14, 2015 Author Share Posted June 14, 2015 This is where I plugged into . Old photo Quote Link to comment Share on other sites More sharing options...
Mof Posted June 14, 2015 Share Posted June 14, 2015 So you can see by the descriptions in the picture what they are right? P.s nice pic Al 1 Quote Link to comment Share on other sites More sharing options...
Matteybean Posted June 14, 2015 Author Share Posted June 14, 2015 Yeap that should solve problem I'll change over 2m long with manky filter Quote Link to comment Share on other sites More sharing options...
Seedy Al Posted June 14, 2015 Share Posted June 14, 2015 report back once done Quote Link to comment Share on other sites More sharing options...
sleeektoy Posted June 14, 2015 Share Posted June 14, 2015 Seedy - you are right on the money with what you have said. I spoke to Matt earlier but I have had the gauge sender vs oil light switch problem before and they work in reverse to each other. Using the gauge sender with an oil light - rev the motor and the light comes on. Use the light sender with a gauge - turn the key on and the gauge goes to full pressure, start the motor and the gauge drops to zero PSI 1 Quote Link to comment Share on other sites More sharing options...
Seedy Al Posted June 14, 2015 Share Posted June 14, 2015 yeah my advice is based on years of experience of making these sorts of mistakes Its all about the learning. Fuck I sound old....... 1 Quote Link to comment Share on other sites More sharing options...
Matteybean Posted June 14, 2015 Author Share Posted June 14, 2015 Yesh the one on right is in my 18r so Ill switch em over 2m n hopefully go a test drive down the road !! Much excite Quote Link to comment Share on other sites More sharing options...
Robbo Posted June 14, 2015 Share Posted June 14, 2015 Sorry to hijack but I've got a similar problem with the 6R in my Corona. Basically the oil pressure light is always on while the engine is running, the sensor is the one of the left like Mattybean's. Presumably that means I also need to find a new oil pressure sender like the one on the right? ..On that note has anyone got a spare 18R sitting around? Should fit the 6R since they're pretty similar. 1 Quote Link to comment Share on other sites More sharing options...
Matteybean Posted June 14, 2015 Author Share Posted June 14, 2015 Hi boxed yeah sounds similiar .. I have an 18r at home which I'll be switching the sensor over tonight so will let ya no how I get on . Pretty sure you can buy em for fuck all from supercheap n the likes of them tho Quote Link to comment Share on other sites More sharing options...
Matteybean Posted June 15, 2015 Author Share Posted June 15, 2015 Sorry to hijack but I've got a similar problem with the 6R in my Corona. Basically the oil pressure light is always on while the engine is running, the sensor is the one of the left like Mattybean's. Presumably that means I also need to find a new oil pressure sender like the one on the right? ..On that note has anyone got a spare 18R sitting around? Should fit the 6R since they're pretty similar. Just got oil filter from super cheap auto 18r oil pressure sensor 15 bucks 1 Quote Link to comment Share on other sites More sharing options...
Matteybean Posted June 15, 2015 Author Share Posted June 15, 2015 Update . Changed pressure sensor over. oil light stays off completely now . It turned on with start up n then went off bit now doesn't come on at all after few start ups I'm guessing because pressure has built up inside the sensor ? It doesn't come on when accelerating anymore either. My sensor from other car looked abit rusty on the outside caseing weather that means anything or not . I also unplugged wire n earthed it on the engine but didn't get no oil dash light . Lol seems to come when It chooses Also found out 18rgeu oil filters r bloody different from 18rgu . This was the only one I could see that super cheAP had listed ... 18rgeu are a little longer which foul on the intake :/ so it doesn't bloody fit !! Now redundant prob wont let me return it either fml . Quote Link to comment Share on other sites More sharing options...
Robbo Posted June 15, 2015 Share Posted June 15, 2015 Just got oil filter from super cheap auto 18r oil pressure sensor 15 bucks Awesome, didn't think they would stock them. Will pop down on the weekend, cheers! 1 Quote Link to comment Share on other sites More sharing options...
Seedy Al Posted June 15, 2015 Share Posted June 15, 2015 It doesn't come on when accelerating anymore either. My sensor from other car looked abit rusty on the outside caseing weather that means anything or not . I also unplugged wire n earthed it on the engine but didn't get no oil dash light . Lol seems to come when It chooses hmmm. thats weird that the light wont come on when you earth out wire. sounds like you might have a break in the wire maybe or a bad earth somewhere Quote Link to comment Share on other sites More sharing options...
