Matteybean Posted June 15, 2015 Author Share Posted June 15, 2015 Yeah I'll investagate it further tonight cheers Quote Link to comment Share on other sites More sharing options...
BlownCorona Posted June 19, 2015 Share Posted June 19, 2015 you didnt put threadtape on the sensor? made that mistake once haha. also id recommend just putting in an oil pressure gauge. the lights are dumb, when it lights up after you've lost all your pressure and potentially damaged something. Quote Link to comment Share on other sites More sharing options...
Spencer Posted June 19, 2015 Share Posted June 19, 2015 Yea you guys really need to check these with a oil pressure gauge. Pretty much mandatory for any old engine to see the condition of the oiling system/bottom end. Use a $20 mechanical for a few drives (get it hot as shit like 30-40min drive) inspect oil pressure at idle and then put the gauge back on the shelf and fix the oil light Quote Link to comment Share on other sites More sharing options...
Spencer Posted June 19, 2015 Share Posted June 19, 2015 Idiot light is still the best, gauge could sit at zero while you roll down the highway oblivious. Best bet is a big fuck off light that is set to just below hot idle oil pressure. Quote Link to comment Share on other sites More sharing options...
downtrail Posted June 19, 2015 Share Posted June 19, 2015 I put loud pizo sirens in the race cars i wire up for this reason. Then you dont need to watch ya dash or gauges itll go off at 95deg water temp or below 15psi oil pressure dependent on motor of course. 1 Quote Link to comment Share on other sites More sharing options...
japawagons Posted June 27, 2015 Share Posted June 27, 2015 Totally agree with Spence, always check oil pressure with gauge, regardless of being suspicious of sender fault. Not something you want to miss the warning signs on... Quote Link to comment Share on other sites More sharing options...
Matteybean Posted June 28, 2015 Author Share Posted June 28, 2015 Yup I brought a oil pressure sensor n installed it and light works perfectly now . Still haven't tested using a guage but I plan on doing so. Yeah I had the sump off before I had it in and looked pretty mint n tidy inside . Quote Link to comment Share on other sites More sharing options...
