Toy-motas new wagon of slow BJ61 cruiser
toy-mota
so over this long weekend i had been busy fixing things.First was to fit a new headunit.Also went to give the rad and front/rear heaters a flush as they didnt work and found the steel pipes that go to the rear heater had been blocked up with oil from a previous blown head gasket,so after ages of trying to rod and flush out the gunk i ended up cutting where it was blocked and just replaced with a rubber joiner.fixed the rust hole and removed someones attempt at making a spare wheel holder.
rust hole in rear guard
caused by this broken badge letting water in and sit
fold up spare wheel holder that i removed,it limited tyre and rim size
so i recon'd a factory 60 series chain one,now works a treat.wonder why it wasnt used in the first place
rear chassis frame rust that will need addressing at some stage,the inside channel and spring hanger are riveted on
also rear bumper getting some bad rust in it
also pics of the Mitsubishi in cab air cleaner,anyone seen these before?
  • 3 months later...
the crusier has been ticking along great.although i lose charge out of my new batteries,i may get one of them exchanged as it never fully charges on the bench either.Changed the wheels/rims to r15 black 4x4 rims with 31x10.5  kumhos,handles alot better.also buying a house so a trailer will be in order to drag behind the truck.
YN57 hilux single cab deck with the crowns old widened steelies
  • 8 months later...
Sadly i just recently sold this truck,due to it needing alot of time spent on keeping it going and getting me to work each week.Which took time out of my other projects.With a kid on the way an upgrade was in order.It needed to be low maintence,low kms,safe,abit of grunt and Toyota.So i traded in the old girl for a 2005 Mark X.3 litre v6 ,6speed tiprontic.Full of bells and whistles and not to bad on the gas or eye.
