vivaspeed Posted January 3, 2015 Share Posted January 3, 2015 Hi everybody, Does anyone have any recommendations or hookups or work for a place that can CNC profile cut out some brackets for me? I've made the design in AutoCAD and surprisingly when I printed and made the template in cardboard it worked fine. So now time for the real thing. Piece is about 110mm x 160mm and is for a brake caliper bracket so would want to be out of 8-10mm steel. Qty 2. Thanks Quote Link to comment Share on other sites More sharing options...
nickrock Posted January 3, 2015 Share Posted January 3, 2015 Go talk to brian at howatt eng he will know who does it Quote Link to comment Share on other sites More sharing options...
flyingbrick Posted January 3, 2015 Share Posted January 3, 2015 http://www.watercut.co.nz These guys rule if u want to use water Quote Link to comment Share on other sites More sharing options...
Seedy Al Posted January 4, 2015 Share Posted January 4, 2015 orsume laser cutters in wingate seem ok Quote Link to comment Share on other sites More sharing options...
flyingbrick Posted January 4, 2015 Share Posted January 4, 2015 Just to expand my previous post. Your best bet is to google Laser Cutting and send your file off to a bunch of shops round NZ for a quote. I did this when I got bits cut (from the place above) and the quoted prices varied an astonishing amount Also you should be specific as some places may plasma cut the brackets when you want the accuracy of laser (for example) Quote Link to comment Share on other sites More sharing options...
Trumpnut Posted January 16, 2015 Share Posted January 16, 2015 Kidd engineering in Upper Hutt does that kind of work and he is cheap. Quote Link to comment Share on other sites More sharing options...
e30-323ti Posted January 16, 2015 Share Posted January 16, 2015 I use accrete in Victoria st Petone, they have a waterjet cutter and an NC fan brake folder. You can see a few bits I've had done in my build thread. Quote Link to comment Share on other sites More sharing options...
Hemi Posted January 16, 2015 Share Posted January 16, 2015 I took my to Norm bullock engineering , but im 99% sure they used orsum laser in wingate, think i had a plate and a ring cut out of 3mm plate think it cost $30?200mm in diameter , I didnt think that was terrible given it was a one of , then again it was a simple cut so yeah. Quote Link to comment Share on other sites More sharing options...
