Zach's 1985 Ke70 Wagon
Backer101
  • 3 months later...
just as a note, you are not going to be able to "just camber them in" and pull the guards. what are the widths and offsets? you could pull it off with some 155/55s, alot of camber and low. no idea how you'd work the back though.
flares are probably your only option really
Hahah i know it looks mexican as shit at the moment, but as i said i only put the spacers on the back to even out the mexicanness, without spacers the back sits perfectly, and the front i think i will be able to get it in there... the C's garage ke70 has the same dimension wheels and they sit in there nicely, those guards are just fully standard and theres not one ounce of camber there.
Wheels are 14x8.5 i think around -20 offset.
Yea il make up some camber plates at work in auckland. yea i want to look into rose jointing them, but not sure how they are for certing?? i know the guards will need some serious shit haha.
pretty easy to cert, just have to have the arms crack tested and some paperwork on the rosejoints. The fancy teflon lined ones are best.
Ive got same size wheels on the front of mine with 185/55s. Have extended my lcas by 30mm and have maxed out my camber plates. Oh and rolled the shit out of my guards. For the rear i will have to make new guards.
my LCAs ended up about 20mm shorter and tophats right in to keep the wheels inside the guards without ridiculous camber
I think that he means that if there is adjustable gear throughout once he has the cert it can be adjusted to whatever setting he wants (even if illegal), once the cert plate is on there won't be many cops or WOF places that actually care/notice
Yea thats exactly what i mean. i was able to do it with my escort, pulled in control arms (using the mods i made to the cross member) and pushed out  the camber plates to have no camber then post cert, boom camber applied.
Just wandering also if modded LCA's show on cert plate as extended or shortened? because if it just says modded LCA's, i have 2 sets of LCA's i could shorten one set and lengthen the other so wofs shouldn't really be able to tell when i put the longer ones in because plate says modded and thats what they will be. Just may be difficult with steering set up and that? ned alignment each time.
  • 6 months later...
