77magnum13hundy Posted April 13, 2014 Share Posted April 13, 2014 Hey y'all running wasted spark but one of the coils seems dickered (crack down the side of it, has dropped on the ground and shit oops), can i set it up to run individual coils if the 1+4 and 2+3 get the same feeds/pulses or is there more to it then that? What would PIckeys have that i could pilfer for this? particular makes models suitable? Setup is g1 link with link ignitor running wasted spark on my 16v 4age, (running 4agze CAS) Cheers rob Quote Link to comment Share on other sites More sharing options...
mjrstar Posted April 13, 2014 Share Posted April 13, 2014 You can still run waste spark on COP, that's how i run the factory ecu on my evo with individual coils... GDI mitsi stuff will be the most common COP setup (but not awesome for all out performance) think ~2000's on RVR (there was one at hamilton PAP last time i was there) If possible track down a 1NZ powered toyota econobox as these coils are a good length, 3S from altezza is another option for coils (slightly shorter I think), and some of the later honda stuff (I run Honda K20 coils on my Mazda) (slightly longer than the 1NZ ones) you won't need to run the ignitor any more as Coil on plug have built in ignitors (please double check this but all the ones i have dealt with have been like this) Quote Link to comment Share on other sites More sharing options...
peteretep Posted April 13, 2014 Share Posted April 13, 2014 when I was at zebra not so long ago there were a few 1nz motors Quote Link to comment Share on other sites More sharing options...
Stu Posted April 13, 2014 Share Posted April 13, 2014 Works fine, have done this before and yep they have an inbuilt ignitor Only issue you will have is driving your tacho as the output from 1nz coils is low level so making your tacho work will be fun Best way will be to use a link output and muck with the resistor inside the tacho When I'm over this god damn bug thing I'll pop out Quote Link to comment Share on other sites More sharing options...
Ned Posted April 13, 2014 Share Posted April 13, 2014 Yeah, you can run them together and you can get both internal and external ignitors for COP so get the right ones Tacho drive is simple but you need a couple diodes, a transistor, resistor or 2 and a coil to create the back EMF signal that the tacho uses Quote Link to comment Share on other sites More sharing options...
Stu Posted April 14, 2014 Share Posted April 14, 2014 I've made them work before by swapping just the resistor out How say you for above Ned? Sounds a lot more legit than my method - MS paint time Quote Link to comment Share on other sites More sharing options...
mjrstar Posted April 14, 2014 Share Posted April 14, 2014 FYI on the coil front the toyota stuff generally has a 4th wire for a tacho signal, the honda ones I have worked with only have 3 wires so no tach signal. Quote Link to comment Share on other sites More sharing options...
Testament Posted April 14, 2014 Share Posted April 14, 2014 the tach signal depends on what kinda of tach it's driving. neds probably talking about one for a typical old car that ran the tach off the coil negative? 1 Quote Link to comment Share on other sites More sharing options...
Ned Posted April 14, 2014 Share Posted April 14, 2014 Yeah, i mean the ones that normally have a (green) wire going to the negative of the coil something like this should work (build/use at own risk) Quote Link to comment Share on other sites More sharing options...
