  • 2 years later...
Lever arm morrie trick is just put thicker fluid in, 30wt I think it was for a firmer road feel
Have also seen a tube with adjustable fitting added to connect the two cylinders to give adjustable dampening
3 hours ago, Tiger Tamer said:
My 64 Hillman Minx lower shock mounts attach to the leaf spring plate. It doesn't seem to cause any problems.
My lancer ones too
Yeah I've seen that, also read a bit about oil thickness as well. I'll pull them apart and give them a service with 30wt.
16 minutes ago, bigfoot said:
My lancer ones too
They do also on my 929 coupe but they are pressed on such a way as to give strength, the kits sold for the mk3 have no gusseting or any strengthening and are just a thinnish extended spring plate to accommodate the bottom shock mount.. For $900 they'd need to be better IMO.
  • 2 years later...
It's maturing, brighton air is so bad it's got some rust spots coming through the epotec primer, and it's in a garage.. Will get there one day
  • Sad 1
