Cliff Curtis' RXII
Vintage Grumble
  • Replies 89
Reason I ask is that I've got a gauge cluster that reads old english.
And that's 'Uncle Cliff Cuz' to you.
Youll soon know when your doing 100mph past the 5-0 ,if you havent been tipped off by the noise from all the 40 year old bits around you
Get the bog off and get it in the big shed,im sure the 4age junkie can hook you up with some steel for a bit of a frame accross under the car to get it up about 600mm of the ground, tack the sills to the frame. Then you have reasonable access under the thing and can tack the mounts/exhaust/floor notch etc all in place and save yourself hours lying on your floor
Wish id done this with my car, as I spend another 1k getting the last of the paint off that I missed.
Got some wicked ideas should be awesome
the axles aren't in that yet are they?  what diff are you using?
Not yet - he did pickup a 9inch housing thats already setup for rx2
Unsure if hes picked a rim/tyre combo or diff head - tried convincing him a quick change rear would be sick :D
Shorten the diff if needed->install tubs->drink beer?
