DoBro Jesus Posted January 22, 2014 Share Posted January 22, 2014 Right, so only just recently my brakes have started playing up. Sometimes I brake and pedal goes right to the floor and other times it's fine, it's fucking inconsistent and annoying, once I pump it a couple of times it comes right when it plays up. I haven't lost any brake fluid as I've kept checking it, it happens about 30-40% of the time while driving. Help?? Quote Link to comment Share on other sites More sharing options...
KKtrips Posted January 22, 2014 Share Posted January 22, 2014 Adjust the rear brakes and see how it goes. Quote Link to comment Share on other sites More sharing options...
AllTorque Posted January 22, 2014 Share Posted January 22, 2014 Try bleeding the brakes next. Quote Link to comment Share on other sites More sharing options...
eke_zetec_RWD Posted January 22, 2014 Share Posted January 22, 2014 check your wheels for play in the bearings or loose discs. this can cause the pads to push the pistons back into the calipers and therefore you need to push them back out (by pumping) to get the pads touching again before any pressure can be built in the system. Quote Link to comment Share on other sites More sharing options...
DoBro Jesus Posted January 22, 2014 Author Share Posted January 22, 2014 Oh forgot to mention brakes had been bled like 2 months ago, ok will check in the morning, it's not detrimental to driving it's just bloody annoying! Quote Link to comment Share on other sites More sharing options...
eke_zetec_RWD Posted January 22, 2014 Share Posted January 22, 2014 you will need to jack it up, grab top and bottom of front wheels and push pull. Quote Link to comment Share on other sites More sharing options...
fuel Posted January 22, 2014 Share Posted January 22, 2014 I'm going for air in the system somehow, probably a leaking master (leaking only a little fluid, but letting air in) or leaking slave in the rear or perhaps a caliper. Quote Link to comment Share on other sites More sharing options...
Ridal Posted January 22, 2014 Share Posted January 22, 2014 I have the same problem. It feels like air in the system and improves if I stamp real hard on the pedal. I've adjusted the rears, bled system multiple times (fixes problem for a short while) and replaced wheel cylinders. Master cylinder isn't very old either. Hoses don't seem to be in bad shape and the calipers don't seem to be leaking. I'm upgrading soon which will replace most parts so I'll see how that goes. Quote Link to comment Share on other sites More sharing options...
