yetchh Posted November 29, 2013 Author Share Posted November 29, 2013 Yeah well the zephyr guys seem to get away with fairly good offset, don't forget that these are fwd 2013 wheels going on a 1965 zephyr so the hubs and bearings are already made for more offset, Also I talked to Royce Clive today, dunno if I'm being a cheap cunt but they wanted $100 per rim to reverse the centers.. there's only 4 50mm welds holding them together, seems a bit exorbitant to me.. Quote Link to comment Share on other sites More sharing options...
flyingbrick Posted November 29, 2013 Share Posted November 29, 2013 Yeah well the zephyr guys seem to get away with fairly good offset, don't forget that these are fwd 2013 wheels going on a 1965 zephyr so the hubs and bearings are already made for more offset, Also I talked to Royce Clive today, dunno if I'm being a cheap cunt but they wanted $100 per rim to reverse the centers.. there's only 4 50mm welds holding them together, seems a bit exorbitant to me.. could you do it cheaper? Quote Link to comment Share on other sites More sharing options...
yetchh Posted November 29, 2013 Author Share Posted November 29, 2013 Yeah, dunno how straight out would be tho.. Quote Link to comment Share on other sites More sharing options...
Rookie Posted December 1, 2013 Share Posted December 1, 2013 Well there is your answer then. Quote Link to comment Share on other sites More sharing options...
yetchh Posted December 2, 2013 Author Share Posted December 2, 2013 The only reason I asked was because it seemed to be about the same price to add bands, looking at the wheel there is only four 50mm welds to cut then reverse the barrels and re weld.. is prob just a flat rate.. I wa going to go ahead regardless but recent events have put it all on the backburner, cheers for the input tho.. Quote Link to comment Share on other sites More sharing options...
eke_zetec_RWD Posted December 2, 2013 Share Posted December 2, 2013 $100 each is all good. Carefully cut weld. Sand up rims to look new. Set up lathe Fuck around setting up center in correct offset. Dial up Tack Check Weld. 2 Quote Link to comment Share on other sites More sharing options...
yetchh Posted December 2, 2013 Author Share Posted December 2, 2013 Thanks mate, that was the info I was after.. Life's a bitch and now I can't justify the money this year, will hopefully have it done before the nationals, been wanting these for a couple of years haha.. Quote Link to comment Share on other sites More sharing options...
