kos420nz Posted October 22, 2013 Share Posted October 22, 2013 Anyone on here know much about toyota crown jzs145 airbag suspension and how it works and if you can make it height adjustable Quote Link to comment Share on other sites More sharing options...
Spencer Posted October 22, 2013 Share Posted October 22, 2013 What are you looking to do? These are bags over a shock, height is monitored by variable resistors on the suspension and you should be able to get a controller ex japan(maybe) they won't lay frame or anything from the factory and are not really useful to retrofit to anything. Ride sweet though. Quote Link to comment Share on other sites More sharing options...
kos420nz Posted October 22, 2013 Author Share Posted October 22, 2013 Basically want to get it to a height where i can drive it comfortably , atm its either fkn jacked ir super slammed and bouncy as hell . Quote Link to comment Share on other sites More sharing options...
AllTorque Posted October 22, 2013 Share Posted October 22, 2013 Can you move / adjust the level sensors at each corner? Quote Link to comment Share on other sites More sharing options...
kos420nz Posted October 22, 2013 Author Share Posted October 22, 2013 Can you move / adjust the level sensors at each corner? No dont think so , havnt really looked . Txt me on 0211580577 if anyone can shed any light Quote Link to comment Share on other sites More sharing options...
Camel Posted October 22, 2013 Share Posted October 22, 2013 easiest way is to adjust/shorten the rods on the height sensors in each corner. Just make sure that you use the isolate button for the air ride system, it should be located in the boot I think. Can get height controllers for these as spencer mentioned which is better in my opinion as its easy to revert to stock Quote Link to comment Share on other sites More sharing options...
kos420nz Posted October 22, 2013 Author Share Posted October 22, 2013 easiest way is to adjust/shorten the rods on the height sensors in each corner. Just make sure that you use the isolate button for the air ride system, it should be located in the boot I think. Can get height controllers for these as spencer mentioned which is better in my opinion as its easy to revert to stock Thank you , are these rods in each corner , can only see the front two , anyone based in chch come look ?? Quote Link to comment Share on other sites More sharing options...
kos420nz Posted October 22, 2013 Author Share Posted October 22, 2013 Thank you , are these rods in each corner , can only see the front two , anyone based in chch come look ?? What does this isolation switch look like ?? Quote Link to comment Share on other sites More sharing options...
Camel Posted October 23, 2013 Share Posted October 23, 2013 They are in the rear as well, one sensor for each corner. The isolation switch should be located in one of the side compartments in the boot. If you have an owners manual it will show in there. I would highly recommmend not touching the rods and sourcing a height controller as if you don't know what your looking at you may botch modifying them. Quote Link to comment Share on other sites More sharing options...
kos420nz Posted October 23, 2013 Author Share Posted October 23, 2013 They are in the rear as well, one sensor for each corner. The isolation switch should be located in one of the side compartments in the boot. If you have an owners manual it will show in there. I would highly recommmend not touching the rods and sourcing a height controller as if you don't know what your looking at you may botch modifying them. Ok thanks for that , where would i source a controller from ? might give adjusting those rods a go . Other option is change it to spring shock if anyone knows of a set floating about ? Quote Link to comment Share on other sites More sharing options...
drift_ae70 Posted October 23, 2013 Share Posted October 23, 2013 You can chop/shorten/modify the rods on the height sensors in each corner. mate did it in his soarer. But its the cheap way of doing it. Try looking on the rear toe arms for the rear height sensor rods This gives you a fair idea about the height you can drive at though Quote Link to comment Share on other sites More sharing options...
kos420nz Posted October 23, 2013 Author Share Posted October 23, 2013 You can chop/shorten/modify the rods on the height sensors in each corner. mate did it in his soarer. But its the cheap way of doing it. Try looking on the rear toe arms for the rear height sensor rods This gives you a fair idea about the height you can drive at though Awesome thanks for that , had a wee look today . Looks like there is one on each side in front but only one in rear ? Did you cut your ones , if so how much did you take off it ? Anyone know of where to get one of these so called controllers , have trooled google but cant comr up with anything ?? Quote Link to comment Share on other sites More sharing options...
Raizer Posted October 23, 2013 Share Posted October 23, 2013 Anyone know of where to get one of these so called controllers , have trooled google but cant comr up with anything ?? http://page.auctions.yahoo.co.jp/jp/auction/178043877 Quote Link to comment Share on other sites More sharing options...
thegreatestben Posted October 23, 2013 Share Posted October 23, 2013 This should be the same as my UZS141. The isolate button was in the glove box and had japanese writing so not easy to figure out. Push it if there is one and the height position light on the dash should flash. The height controller units out of japan are generic, there are microswitches on the back which you position to suit your specific model (easy info to find if you google) the specific part is the loom to suit, again easy to research. I had a controller in both my Celsior and my Crown. The Crown was easier to install as the height computer was under the centre console whereas the Celsior's was right down the back in the right hand side of the boot. Quote Link to comment Share on other sites More sharing options...
thegreatestben Posted October 23, 2013 Share Posted October 23, 2013 The controller you want is an ASE664 Quote Link to comment Share on other sites More sharing options...
drift_ae70 Posted October 24, 2013 Share Posted October 24, 2013 Only one in rear sounds about right, on the left rear. I think he did cut them, not sure how much. cant remember though was back in like 09. Might pay to take note of length etc before pulling them out and chopping though Quote Link to comment Share on other sites More sharing options...
kos420nz Posted October 31, 2013 Author Share Posted October 31, 2013 Anyone know if jzs145 crown are same suspension bolt up as a jzs147 aristo ? Quote Link to comment Share on other sites More sharing options...
