kos420nz
New Members
kos420nz's Achievements
Member
Member (2/5)
0
  1. Anyone know if jzs145 crown are same suspension bolt up as a jzs147 aristo ?
  2. Awesome thanks for that , had a wee look today . Looks like there is one on each side in front but only one in rear ? Did you cut your ones , if so how much did you take off it ? Anyone know of where to get one of these so called controllers , have trooled google but cant comr up with anything ??
  3. Ok thanks for that , where would i source a controller from ? might give adjusting those rods a go . Other option is change it to spring shock if anyone knows of a set floating about ?
  4. What does this isolation switch look like ??
  5. Thank you , are these rods in each corner , can only see the front two , anyone based in chch come look ??
  6. No dont think so , havnt really looked . Txt me on 0211580577 if anyone can shed any light
  7. Basically want to get it to a height where i can drive it comfortably , atm its either fkn jacked ir super slammed and bouncy as hell .
  8. Anyone on here know much about toyota crown jzs145 airbag suspension and how it works and if you can make it height adjustable
  9. kos420nz
    Toyota 3TC
    Done all of the above
  10. kos420nz
    Toyota 3TC
    Hi Guys, I have a Corona tt132 have recently , put new spark plugs in , set timing , leads , coil , cleaned carb and set fuel mix to 2.5 - 3 turns out, set idle mix , all that jazz . now has devoleped a miss up high around 5 grand and above. Any ideas what it could be, am stumped ...
  11. keep us posted on this august meet up in hamner .
