WhangareiKE70 Posted September 20, 2012 Share Posted September 20, 2012 I think the title pretty much spells out my idea (not sure if it's a good one yet that's why I am making this thread). Only piece to add is that it will be going in a Datsun 720 4wd, and I am already committed to the idea of a VG30DE at least. However I have a few questions on this one: 1) Where/who would be able to make up a manifold for this? 2) If I were to perform a body lift on my 720 ute, would I get more space to mount it under the bonnet? (seems like a very simple/dahuuur question, and it is, but I have a tendency to miss the obvious things). 3) Another dumb question, will the VG30DETT (minus the turbos) work better than the VG30DE? As it probably has a lower compression ratio and is already made for boost? 4) Can anyone recommend a suitable supercharger? Not looking for super boost, just increase in low down torque for towing, as well as obvious wank factor. Also any other thoughts on this, let me know. It seems like a good idea to me as opposed to turbocharging due to the instantaneous torque of a supercharger vs. a turbo(s), as well as space in the 720's engine bay. Thoughts/answers? Quote Link to comment Share on other sites More sharing options...
Muncie Posted September 20, 2012 Share Posted September 20, 2012 use 300zx TT engine and pathfinder box for 4wd. dont waste time with supercharger those VG30DETT engines have next to no lag you'd lose power fitting a blower. Quote Link to comment Share on other sites More sharing options...
DJZ Posted September 20, 2012 Share Posted September 20, 2012 How about a VG33ER supercharger? Quote Link to comment Share on other sites More sharing options...
HighLUX Posted September 20, 2012 Share Posted September 20, 2012 What do those come out in?? You will get more room between engine and bonnet with a body lift as your raising the body away from the chassis which is what ya engine is bolted to. Quote Link to comment Share on other sites More sharing options...
RUNAMUCK Posted September 20, 2012 Share Posted September 20, 2012 Nissan frontier Trucks. (USDM spec) I have one of those exact blowers in the shed. Quote Link to comment Share on other sites More sharing options...
HighLUX Posted September 20, 2012 Share Posted September 20, 2012 WIki reckons they only make 210hp? Seems weak for a 3.3 V6 with a blower or does the internet lie Quote Link to comment Share on other sites More sharing options...
DJZ Posted September 20, 2012 Share Posted September 20, 2012 A supercharged 3.8 Commodore motor is apparently only 221hp. The VGs are only single cam per bank, probably low compression and low boost too, they are a truck motor after all. Quote Link to comment Share on other sites More sharing options...
R100 Posted September 20, 2012 Share Posted September 20, 2012 The supercharger will have to offset to one side (RHS) due to the distributor location. Unless you mount it up higher to clear the distributor. Then it will be thoroughly through your bonnet. What computer where you thinking of using ? Factory VG30DE loom and ECU or aftermarket ? My understanding is the VG30 has an engine loom that's integrated into the rest of the under bonnet/dash wiring and is not easily separable like the 1JZ and 1UZ Toyota engine looms. Quote Link to comment Share on other sites More sharing options...
DJZ Posted September 20, 2012 Share Posted September 20, 2012 A Z32 VG30DE doesn't have a distributor and the loom looks pretty separate, his motor/loom/ECU is sitting at my work at the moment. Quote Link to comment Share on other sites More sharing options...
R100 Posted September 20, 2012 Share Posted September 20, 2012 Im not to clued up on the different VG30 engines. I have a VG30 in my terrano and it has a distributor. Its an old 1991 shitter though Quote Link to comment Share on other sites More sharing options...
fuel Posted September 20, 2012 Share Posted September 20, 2012 yes but that's SOHC, we're talking about a VG30DE DOHC here. Quote Link to comment Share on other sites More sharing options...
badnewz Posted October 14, 2012 Share Posted October 14, 2012 if u use a 300zr or leopard vg30de they have a off set intake manifold allowin room o. drivers side for supercharger the des will happily handle up to 8psi also the eprom ecus are easily re writeable to keep costs down Quote Link to comment Share on other sites More sharing options...
