mutiny Posted March 19, 2012 Share Posted March 19, 2012 so been trying to fix the mrs car, its a 92 mirage motor it self runs beautifully until you put it into drive, then it shudders like a bitch, dont really know fuck all about front wheel drive stuff or automatic gearboxs, what possibilites are there? Quote Link to comment Share on other sites More sharing options...
ProZac Posted March 19, 2012 Share Posted March 19, 2012 What engine does it have? Quote Link to comment Share on other sites More sharing options...
fuel Posted March 19, 2012 Share Posted March 19, 2012 and when exactly does it shudder - as soon as you put it into drive and it's idling, or while it has some revs and driving? what's the idle speed set at? how are the engine mounts? these are the first things I would be checking. Quote Link to comment Share on other sites More sharing options...
mutiny Posted March 19, 2012 Author Share Posted March 19, 2012 4g31 from memory. it shudders as soon as it goes into gear, is relativly smooth while driving, bit sluggish etc. engine mounts are good. is there anything which mechanically makes the motor rev a couple hundred rpm higher when it goes into gear or anything? Quote Link to comment Share on other sites More sharing options...
Llama Posted March 19, 2012 Share Posted March 19, 2012 ^Motor should be reving higher in neutral than drive (at idle) on most autos I think. Are you sure it's not just resonant vibration? Our 94 corsa has terrible resonance at about 650 where it idles in drive, but if you rev it even slightly it stops. Quote Link to comment Share on other sites More sharing options...
mutiny Posted March 19, 2012 Author Share Posted March 19, 2012 It could be but it shouldn't be that bad. Almost eels like it's going to stall Quote Link to comment Share on other sites More sharing options...
Valiant Posted March 19, 2012 Share Posted March 19, 2012 Sounds like it's missing. check the plugs/leads/ignition system. Quote Link to comment Share on other sites More sharing options...
mutiny Posted March 20, 2012 Author Share Posted March 20, 2012 Na because it idles and revs perfectly in neutral, but yea did timing plugs etc already Quote Link to comment Share on other sites More sharing options...
Borgweiser Posted March 20, 2012 Share Posted March 20, 2012 Check engine mounts, air leak between afm and manifold? Quote Link to comment Share on other sites More sharing options...
mutiny Posted March 20, 2012 Author Share Posted March 20, 2012 should have said, its carby Quote Link to comment Share on other sites More sharing options...
Valiant Posted March 20, 2012 Share Posted March 20, 2012 Na because it idles and revs perfectly in neutral, but yea did timing plugs etc already Often the ignition can play up under load. There is something that can fail in the carb that gives them a vacuum inside the carb. I can't remember what though... Quote Link to comment Share on other sites More sharing options...
fuel Posted March 20, 2012 Share Posted March 20, 2012 wont be a 4G31.. would be a 4G91 if its one of those import 1500cc DOHC electro-carb models, otherwise 4G13, 4G15 or 4G92 injected if NZ-new. Quote Link to comment Share on other sites More sharing options...
Yammies Posted March 20, 2012 Share Posted March 20, 2012 what is it idling at? I'm assuming that as it's an auto it will have a revcounter. try adjusting your base idle slightly higher to see if it makes a difference. Quote Link to comment Share on other sites More sharing options...
mutiny Posted March 20, 2012 Author Share Posted March 20, 2012 yeah is a 4g13 sorry, unsure what it is idleing at, is definatly enough though. doesnt have a rev counter. pretty much given up now/its not really my problem anyway Quote Link to comment Share on other sites More sharing options...
