Toot Toot Timmy Posted February 21, 2012 Posted February 21, 2012 Have just given my filter a wash and was wondering if there is a better and more economical solution to the specific stuff ITG or K&N sell. An aerosol can of something that will last for years would be great! Quote
drtdvl Posted February 21, 2012 Posted February 21, 2012 I've got some JR racing stuff you can use... It's blue - like your car. Also there is a big argument about air filter oil and it doing bad things to maf's... you car i think is MAP tho.... Quote
Toot Toot Timmy Posted February 21, 2012 Author Posted February 21, 2012 JR racing, where do you buy that? I think its all good as long as you only mist on a small amount,, its only there to collect extra dust so no need to coat it heavy. I have a ITG filter that is foam so it wont make its way through. Amazing how much crap they pick up when you wash them out! Quote
Snoozin Posted February 21, 2012 Posted February 21, 2012 I have a K&N filter service kit you are welcome to have if you want it, has been used to wash and oil one small panel filter so there's plenty left. Quote
Toot Toot Timmy Posted February 22, 2012 Author Posted February 22, 2012 Cheers. You guys are awesome. Was just wondering if anyone knew of something that would work so I could buy can off it and use it for the next ten years without having to worry. looks like this may be the go. http://www.cycletreads.co.nz/products/2 ... ter_o.aspx Quote
Taistorm Posted February 22, 2012 Posted February 22, 2012 Castrol make one that does the job swell. Remember it being quite cheap. If I can find mine you can have it, only used it once so probs 3/4's of the aerosol remaining. Edit: Misread, thought you meant a cheaper Airfilter Oil alternative. Quote
Dell'orto Posted February 22, 2012 Posted February 22, 2012 Cheers. You guys are awesome.Was just wondering if anyone knew of something that would work so I could buy can off it and use it for the next ten years without having to worry. looks like this may be the go. http://www.cycletreads.co.nz/products/2 ... ter_o.aspx Was going to suggest Bel Ray...they do a liquid form too, which lasts forever and a day. A little goes quite a way Quote
Hemi Posted February 22, 2012 Posted February 22, 2012 i use crc but i use a cheap $30 pod filter . havent noticed the maf have a hernia over it Quote
