Raizer Posted January 7, 2013 Share Posted January 7, 2013 5 speed it. Its a fuck around getting the kent box behind the pinto and there that weak even without dumping the clutch you will probably kill it. I used to literally snap them down changing with a worked 1600. Quote Link to comment Share on other sites More sharing options...
Josh027 Posted January 7, 2013 Author Share Posted January 7, 2013 Considering all options aye, if I could find a sierra 5 speed conversion kit with driveshaft to suit would be going with that! Quote Link to comment Share on other sites More sharing options...
Goblin Posted January 8, 2013 Share Posted January 8, 2013 would be keen to buy the 1600 if u go pinto lol Quote Link to comment Share on other sites More sharing options...
Josh027 Posted January 8, 2013 Author Share Posted January 8, 2013 Looks like its gonna be a while before I can sort everything for the conversion with going to do it once, do it right and all that. UNLESS I can find a kit for the gearbox side Quote Link to comment Share on other sites More sharing options...
hulse12 Posted January 9, 2013 Share Posted January 9, 2013 Leaves look sweet bro! I've noticed my car leans to the left a lil bit too.. Well not anymore since I got adjusties up front but I think the back still has a little sway to the right.. Car's coming along mint! Quote Link to comment Share on other sites More sharing options...
mfordy Posted January 9, 2013 Share Posted January 9, 2013 Shock absorbers don't control the ride height - thats determnined solely by the springs and yours are probably a bit tired!.. Get them reset or replaced to the correct height. But while you're at it, you should probably replace the shocks and bushes as well - depends how deep your pockets are. Koni do a good range of standard and performance shocks. Quote Link to comment Share on other sites More sharing options...
Sparkle Posted January 26, 2013 Share Posted January 26, 2013 Looks better lower! Did ya use Archers in the end? For shocks, go see the boys at Autolighn on campbell? st. Tell them Cam that used to be at Heavy Trucks sent you. Quote Link to comment Share on other sites More sharing options...
Llama Posted August 15, 2013 Share Posted August 15, 2013 Few months late, the springs may have settled after so long and hence given you the uneven look, but (on MGs) atleast it's actually the shell that slowly creeps over time far more often that it is the springs on one side gone soft. Just my 2c Quote Link to comment Share on other sites More sharing options...
Josh027 Posted October 9, 2014 Author Share Posted October 9, 2014 I feel like me replying is like being very late to my own party! Have learnt to love the little pimp limp it has to the right - once the big build gets underway it shall hopefully be no more! Quote Link to comment Share on other sites More sharing options...
locost_bryan Posted October 9, 2014 Share Posted October 9, 2014 For brake and diff options, go visit palmside.co.nz, and have a look at their rally stuff. Should give you some ideas how the factory did things. Quote Link to comment Share on other sites More sharing options...
J-W-G Posted October 10, 2014 Share Posted October 10, 2014 Diff go B1600 or courier. Brakes go wilwoods or princess with 257 mm ford laser disks. Quote Link to comment Share on other sites More sharing options...
Josh027 Posted October 10, 2014 Author Share Posted October 10, 2014 Palmside definitely are the biz for that stuff! Will definitely be getting in contact with them for advice and whatnot Will be probably going wilwoods for the brakes. Not too sure about diff - lsd for sure though 1 Quote Link to comment Share on other sites More sharing options...
