J-W-G Posted October 3, 2011 Share Posted October 3, 2011 Hey just wondering if a 4 link kit and coilover setup would be worth it for a daily/Occasional drift/track car to reduce sway in the back Quote Link to comment Share on other sites More sharing options...
Gaz Posted October 3, 2011 Share Posted October 3, 2011 Not worth the effort for daily.. Worth it for a race car yes. Quote Link to comment Share on other sites More sharing options...
QCADTA Posted October 3, 2011 Share Posted October 3, 2011 put a panhard rod in it would be cheapest and uprated shocks. Quote Link to comment Share on other sites More sharing options...
J-W-G Posted October 4, 2011 Author Share Posted October 4, 2011 Panhard rod, turrets and 2 link kit maybe? Quote Link to comment Share on other sites More sharing options...
nick_m Posted October 4, 2011 Share Posted October 4, 2011 Some argue that panhard bars and leave springs fight each other because a panhaard bar moves in an arc it pushes the diff slightly sideways while the leaf springs are trying to locate it too. Definitely get some good quality shocks in the rear. Maybe added another leaf to the spring pack to stiffen it up a little. Wasnt there some models of mk2 escorts that came with a rear swaybar (im not a escort fiend, im going off memory) I reckon add a small rear swaybar and some good quality shocks and the two link would be a good idea too it your going to do drift days Quote Link to comment Share on other sites More sharing options...
camo_78 Posted October 4, 2011 Share Posted October 4, 2011 my old 81 mk2 sedan(now owned by Horse25) had a rear swaybar fitted,about 12mm from memory.as the others say though,good shocks etc,maybe do all bushes too,every escort of come across had a habit of chewing out the leaf spring shackle bushes Quote Link to comment Share on other sites More sharing options...
J-W-G Posted October 4, 2011 Author Share Posted October 4, 2011 Bushes, shocks, new leafs for sure Just am not sure wether a 2link kit, panhard rod and turrets could work together? Quote Link to comment Share on other sites More sharing options...
Gaz Posted October 4, 2011 Share Posted October 4, 2011 If you are going to the effort of turrets then you could put a coilover in there.... I wouldnt bother with turrets tho.. Do it in stages and decide as you go. 1. New bushes 2. Remove top rubber bush and solid mount shocks as per rally design book 3. Install mk1 or mk2 rear sway bar if not already there 4. New shocks, adjustable Gaz shocks are really good and cheap 5. Remove 1 leaf and put one stiffer pne in there. 6. Install 1 tramp bar (1 is easier to get right yourself than 2) 7. Install adjustable panrod if your having trouble with diff location 8. I dont think turrets are necessary and I think you may loose ya back seat with them? Check out low'n'slows build thread as he has had both an escort with simle mods and now one with turrets etc. Gaz Quote Link to comment Share on other sites More sharing options...
J-W-G Posted October 4, 2011 Author Share Posted October 4, 2011 Sweet thanks Gaz Quote Link to comment Share on other sites More sharing options...
Truenotch Posted October 10, 2011 Share Posted October 10, 2011 If you get the panhard rod close to horizontal / pointing down slightly on the diff end there shouldn't be too much side-to-side movement. This depends on how hard your springs are too. Panhard, rods and leaves seem to work well in lownslows escort and numerous pre65's out there, as well as a number of classic escort and corolla race cars that I've seen. Quote Link to comment Share on other sites More sharing options...
Gaz Posted October 10, 2011 Share Posted October 10, 2011 Russel is running coilover rear aswell as the leaves I belive, same as Aidens Anglia. Gaz Quote Link to comment Share on other sites More sharing options...
eke_zetec_RWD Posted October 10, 2011 Share Posted October 10, 2011 top links help alot if your car has a bit of grunt. mine never axle tramps at all Quote Link to comment Share on other sites More sharing options...
Shandangles Posted October 10, 2011 Share Posted October 10, 2011 if your worried about diff location with a panhard, why not use a watts link?? Quote Link to comment Share on other sites More sharing options...
J-W-G Posted October 11, 2011 Author Share Posted October 11, 2011 The cost of it! Plus its just my daily ( For now ) ive got bout 5k gravel road so she slips about like crazy. Ill go 2link and panhard rod in future Quote Link to comment Share on other sites More sharing options...
Shandangles Posted October 11, 2011 Share Posted October 11, 2011 why is setting up a watts link going to be considerably more expensive? lost of production cars came out with them, if they were massively expensive they would have all had panhards Quote Link to comment Share on other sites More sharing options...
J-W-G Posted October 11, 2011 Author Share Posted October 11, 2011 Really? I didn't know that haha just yeah the ones from palmside and Burton are excess of 750 dollars Quote Link to comment Share on other sites More sharing options...
Shandangles Posted October 12, 2011 Share Posted October 12, 2011 do they do a bolt/weld in panhard/watts link kit?? fuck thats sweet if they do Quote Link to comment Share on other sites More sharing options...
Gaz Posted October 13, 2011 Share Posted October 13, 2011 Goto Pickapart, find car with watts linkage and buy it for a couple of bucks/fuck Burtons. Gaz Quote Link to comment Share on other sites More sharing options...
1vaknd Posted October 13, 2011 Share Posted October 13, 2011 i got my watts link pivot out of a early 90's coon from pick a part. $14 from memory Quote Link to comment Share on other sites More sharing options...
J-W-G Posted October 14, 2011 Author Share Posted October 14, 2011 $14 bucks fuck me! Pick a part here i come! Quote Link to comment Share on other sites More sharing options...
