troyzakp60 Posted September 19, 2011 Share Posted September 19, 2011 i wasnt getting a push start out a drive n left my door open then there was a big! pot plant and my door hit it and bent in the hinges i think but also put a wee dent in the front of the door after the guard.the door dosnt line up when its closed,ill get pictures when i can just wondering if anyone can help me fix this or point me in the right direction to getting it fix christchurch area cheers Quote Link to comment Share on other sites More sharing options...
Beaver Posted September 19, 2011 Share Posted September 19, 2011 its a long shot, but perhaps a panel beater might be worth a shot...... Quote Link to comment Share on other sites More sharing options...
My name is Russell Posted September 19, 2011 Share Posted September 19, 2011 I would start by tring to find a new door, whats the car? Quote Link to comment Share on other sites More sharing options...
SP450andLE Posted September 20, 2011 Share Posted September 20, 2011 Problem is probably with the panel where the hinges connect to, not the door itself. Happened to my Bro's (lincooln's) Vitara in the wind one day. We have just left that as is though, so haven't seen whether it is easy to fix or not Quote Link to comment Share on other sites More sharing options...
troyzakp60 Posted September 20, 2011 Author Share Posted September 20, 2011 yeah i dnt think it the door,it a 2 door kp6o ill try get some pics up Quote Link to comment Share on other sites More sharing options...
Valiant Posted September 20, 2011 Share Posted September 20, 2011 Doesn't look to bad. You should able to lift that door up by hand or gently with a jack and a piece of wood. May be buy a lower door hinge and tap the pillar back into shape if need be. Quote Link to comment Share on other sites More sharing options...
troyzakp60 Posted September 20, 2011 Author Share Posted September 20, 2011 yeah i tried jack and wood,a little difference my just take door off in weekend and have a fiddle round with it Quote Link to comment Share on other sites More sharing options...
bubblegoose Posted September 20, 2011 Share Posted September 20, 2011 i doubt it would have moved the a-pillar, try slackening off the hinges then lifting it up. if not then youve bent the hinges/door Quote Link to comment Share on other sites More sharing options...
troyzakp60 Posted September 20, 2011 Author Share Posted September 20, 2011 mean will do so it could be an easy fix Quote Link to comment Share on other sites More sharing options...
Bling Posted September 20, 2011 Share Posted September 20, 2011 Going by the photos although that 'arm' might be damaged, pretty sure its only to limit the door from opening too far. Compare hinges / area they bolt to, to the other side and go from there. Just taking a guess, photos don't show hinges. So that's where i'd start. I don't recall if the hinges are the same left to right or not. If they are, swap the passenger side hinges over and see if that fixes it. If it does... then you know what to replace. Quote Link to comment Share on other sites More sharing options...
troyzakp60 Posted September 20, 2011 Author Share Posted September 20, 2011 yeah i have a feeling it is the hinges now,im going to take the gaurd of in the weekend and see what i can do Quote Link to comment Share on other sites More sharing options...
EvoBilly Posted September 29, 2011 Share Posted September 29, 2011 the hinges usually have a bigger hole so they sort of slotted if you loosen the bolts off and slide it up usually its easier to take the guard of and loosen shut the door then lift a little to take the weight off and do them up then test till its right Quote Link to comment Share on other sites More sharing options...
