troyzakp60
Everything posted by troyzakp60
I have two options for my exhaust at this stage. Either a 2.75 with a resinator and muffler or 2.5 to resinator to 3inch. I think ill use the 2.75 at this stage. But it should be running pretty soon, we have put most the wiring in just need a mate to wire some dash wires ect up. I also took my wheels in the other day to be widend. Ive got with 9s on the rear and 8.5 in the front with a staggerd offset.
its been a while since ive updated this . ive finally got the 3tgte back from the rebuild.its been a long wait but defiantly worth the wait. alot has happend while. so as soon as i got it back we started to put it in. not much was needed to be done, it all bolted in and intercooler piping was like it was meant to fit.
sorry bout terrible photoso ive changed my mind with the 2tgeu and im now moving to a 3tgte. i found one straight away that my mate was building for his liftback but he decided to go with another engine choice. so ive now sold the 2tgeu that was in the TE and have bought the 3tgte set-up at the moment it is still in the shop getting built. its had the whole bottom end re built , rings ect. should be done by the end of the week or so. it comes with everything but there is a couple things i need to get still. intercooler and and exhaust made up which should be an easy task Also may get the engine bay painted while engine is out as someone has matte blacked it Also got some new new wheels. ssr mk2 type x2 13x9 bands and the rest 6.5 came with 6 centres and bands. i am definitely going to do some guard work but that's sweet. my plan is to widen x2 more of the bands , maybe not into 9s but 8.5s or 8s to run at the front. and get them centres painted red and the bands a metallic silver. maybe something like this.
hey guys here i have a te71 liftback //oldschool.co.nz/index.php?/topic/34696-troys-te71-liftback-discussion/ it is factory 3tc with a t50 box but some one had put a 2tgeu in it. did most of the conversion pretty well but the wiring was abit dodgy. it came with compress springs at the front with shorter inserts and cobras and monroe gts for the rear only one little dent that bothers me but will be and easy fix part from that the body is pretty straight my mates wheels here 14x6.5 i have some work equips that i will be putting on it once i sort some other stuff it came with the engine not going, suspected bottom end. i susd out and engine as soon as i got it and this 2tgeu popped up that had been worked ect so i had to. the engineas soon as that arrived i got it in asap and was very happy with the result. once it hits power band it really goes tried to tidy as much as the dodgy wiring as possible. had a couple of problems with it running but it was just alternator and had a couple spare any way. i bought some kp61 fender mirrors like these ones but straight black basically the same as te71 mirrors and some twin headlight surrounds and grill. i really want to run them but its hard to find all the parts to do so and im %90 sure they are going to fit easy. next im wanting to find some buckets to see if i can actually make them fit i also bought a pair of import bumpers for it which is pretty cool. the front one bolted in just stuck out half and inch more than normal but nothing noticeable. ill give it a good clean and maybe paint it up. the rear is going to be a bit harder cause they slot in the back rather then bolting on to the mounts same as factory but all i will have to do is cut some squares into the back and make some mounts also put a pair of the equips on but really didnt like the fitment a and they needed lower pro tyres. im going to but some new wheels for it some thing a bit wider and an offset that suits mounted up the one side of the mirrors and they turned out good . a wee pic with DUXZ GSR (http://oldschool.co....age__hl__lancer)
do i need 3tgte loom and ecu?
Hey there i have a 2tgeu which has had a bit of work done to it. Cams, ported out ect. im wanting to know what needs to be done to turbo it. i know i can use 3tgte parts. but what exactly would i be using from a 3t? what is all that needs to be done? and would it be hard to do? im not going to be thrashing it round hard so just run low boost i guess. cheers
8inch front 8.5inch rear i think haha
Sweet man will do
cheers man that would be so so helpful give me a txt if you do end up having them 0278569908
Ive gone with the 3t it was a mean deal. a fresh rebuild and box and heaps of stuff really cheap.
ive seen the bare short block and the long block would you be able to post the other ones up
yeah ive priced up most stuff and ive lost my license so me and mates have a lot of time to much around on it . if a decent 5k worth buying popped up i would Definitely be keen but the 3t ive got sorted has been rebuilt and comes with a gearbox new clutch and all that. and a pretty dam good price. the only expensive part about putting a 5k in would be actually buying it . but then depending on how it came. ive heard that if you just put a little work into a 3t it goes alright.ive got a webber sitting round too haha
I know so heavy! Haha. I Just want to keep the cost down and im about to pick up a mean deal off a mate. If i found a 5k i would be so much more down for that.
will be runnig a t40 or t50 . and what are some options for diff?
what exactly needs to be done, what mods need to be made to put a 3t into a kp60? i know mounts will need to be changed. where can i get mounts to suite? in chch or just anywhere. how hard to convert to hydro clutch ? just wanting to know what needs to be done any help cheers
just wanting to know how hard would it be to replace the nz new flat front bumpers with the big import bumpers? im guessing the mounts will be different has anyone done this before?
no not jono.but this could be the same guy thats stealing them
my mates pulsar got stolen and same thing happened , found it on the road with nothing in it.
yeah so eally this cam wouldnt be the right choice? what would a good cam with the weber ect
cam choice 4k is this a good cam choice for a 4k with a 28/36 weber carb and ectractors? here is the trade me link http://www.trademe.co.nz/Browse/Listing ... =406715706 if it dosnt work here are the cams specs "Type: Very Fast Road / Wade 140 / Max road special Specifications: IN Advertised duration at .017": 290 degrees EX Advertised duration at .017": 290 degrees IN Duration at .050": 239 degrees EX Duration at .050": 239 degrees IN Cam lift:.296" EX Cam lift .297" Lobe separation: 106 degrees If you are after serious horsepower this cam is it. Still street drivable. This cam will have a very lopey idle and is suitable for high performance street use and/or rally applications. Power band 3000-8000 rpm. This cam is straightened, undercut, precision ground and phosphate edged to aid with the running in process. This cam is ready to install and ready to run."
Lancer EX 4G32B point gap, dwell and idle settings
troyzakp60 replied to Scrubb's topic in Tech Talk
so to set the timin 4 a 4g32 in a ex i jus refer to above? -
yeah that a good point,i have evrything out of 1600 so it shouldnt be to much trouble "hopefully"
really? there i tiny wee kink in the one i have not sure if its algoods or not will get pictures up at some stage,the engine sat in there fine and came out fine so would it be fine putting it into the 1200? the 1600 was in a crash
